-   1st Gen. Ram - All Topics (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/)
-   -   3200gsk install gone wrong (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/3200gsk-install-gone-wrong-224530/)
Bogurt Nov 25, 2008 08:58 PM
as of two hours ago, i have a 3200 gov spring. I followed the directions carefully and had no trouble seeing what went where and how everything worked. My throttle is indexed on the same notches it was when I pulled it apart. The problem: truck idles fine and starts, but if i give it any throttle, it just idles down and dies as if I where pulling the shutdown lever. I don't have a fuel shutoff solenoid. My guess is that the full fuel screw is not properly adjusted. The screw stops and wont go any further( it might have gotten tweaked.) any help would be great- Brandon
Bogurt Nov 25, 2008 09:36 PM
The pin that rides on the afc cone is not visible that explains why no fuel right? I tried maxxing the full fuel screw. now, it hazes at idle with smoke screw all the way .
Gutterslug Nov 25, 2008 10:29 PM
Dude I had the EXACT same problem on my truck. Make sure when you index the throttle that you do NOT push down on the shaft even just a little. Been a while since I did mine but iirc, ya have to hold it up a bit and make sure not to budge it. If that's not it then I have no idea. You can search my posts and find the link for it though. Search is your friend :cool:
-Mike
Bogurt Nov 25, 2008 10:37 PM
Ill pull off the lever and re index it. The lever sat on the splines cleanly though.
Bogurt Nov 25, 2008 11:55 PM
i pulled it off and the lever did move. thanks, now i just need to fix the pulsating idle
Bogurt Nov 26, 2008 02:42 PM
on the idle, every time i turn the full fuel screw in, my idle starts pulsating. If i back it out it runs fine but at a loss of power. Also, if i have the screw adjusted farther in, i can rev the engine and let off the throttle and the engine's rpm falls back down to 200-300 rpm under idle and then recovers or dies.
gear jammer 91" Nov 26, 2008 07:33 PM
I'm not sure about your pulsating idle, but the engine dieing upon decelerating could be due to a dead lift pump. You will need to put a fuel pressure gauge on your rig, at least temporarily and check the pressure. Unfortunately I don't know what the fuel pressure need to be, somebody will jump in here with that info.
caleb keller Nov 26, 2008 09:31 PM
i would assume its the same as a vp truck which is no less than 5 psi at wot.
wannadiesel Nov 26, 2008 09:49 PM
You still have the throttle lever clocked 1 spline too loose.
Bogurt Nov 27, 2008 03:40 AM
i had the throttle clocked at stock and it would not idle below 1100 even with low idle screw removed. So, i re-clocked it one spline and was able to adjust it to idle at 700-800. The pulsating idle is gone, but when I turn the full fuel screw in further, it doesnt start to run away as it did previously. It simply revs up and then back down to below idle. Should i still try changing throttle index by one spline? thanks and happy thanksgiving
Bogurt Nov 27, 2008 04:05 AM
also on the lift pump, before i started the engine at first, i used the primer on my lp. I noticed that it did not spring back like it once did. i started the truck and forgot to tighten 2 of the injector lines i had loosened to rotate the pump[duhhh] after squirting fuel all over my driveway and listening to the truck vibrate and sound like my shovelhead, i shut down, tightned everything und used the primer again it sprang back like normal. the truck runs and drives great and still throws off a decent bit of soot, but.... i want my power screw back the way it was. while im at it, what do you recommend for a pressure gauge? i dont care if its mechanical or electrical as long as its reliable and inexpensive. I planned on upgrading my lp for a while now. Should i go with a piston lp, an electric pump, or a new or reman oem. I want to make sure my truck has the fuel it needs at its new found highish rpm. again, trying to stay on the cheap side
wannadiesel Nov 27, 2008 07:18 AM
Yes. Having it drop below the set idle speed and then recover is the classic sign of being one tooth too loose.
The primer lever will feel different depending on where the cam stopped. What you are noticing is normal.
Bogurt Nov 27, 2008 11:09 AM
thanks for the info ill go re-adjust it and get back with the results.
gear jammer 91" Nov 27, 2008 01:22 PM
On the lift pump, I replaced mine with the low pressure piston pump and I have been very happy with the results. It really depends on what you plan to do with the truck though. My setup wouldn't supply enough fuel for some of the big injectors that you can run in these trucks.
bgilbert Nov 28, 2008 10:20 AM
This is because you have the fuel screw threaded in way too far.
If you had your fuel screw threaded in at a reasonable point it would not idle at all. At this index point you are losing range of throttle motion, hence the power loss.
Keep in mind not all injection pumps will respond the same as others. Ie, some will run away, some won't, some quicker or slower than others at different fuel levels, range of throttle indexing etc.
I suggest indexing back to where it idled at 1100rpm, then backing your fuel screw out to where it will idle reasonably. If you want more fuel, do with injectors or afc mods, not the fuel screw.
