-   3rd Gen High Performance and Accessories (5.9L Only) (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/)
-   -   Injector Questions (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/injector-questions-219228/)
trx Oct 5, 2008 10:17 AM
Injector Questions
Hey guys I am looking for a little more power, was thinking that adding a set of injectors would be next thing in line that needs to be done. Am I on the right track or should I address something else. Would like to know the downside of adding injectors ie install time, is it going to run hotter, not going to tow as well etc... Any help is appreciated. Thanks
mpracehemi Oct 5, 2008 12:21 PM
From what I've read and with what you've done as for mods. I think you could step up to the 90's size inj. and produce some descent power.
Brian Lent Oct 5, 2008 03:34 PM
I have 90-110 hp injectors and still tow fine with the smarty on three. Empty I still get a little hot 1600+ with smarty on 7 but I don't know much about the garret turbos. I wouldn't go ant bigger and still tow.
trx Oct 5, 2008 07:38 PM
Being I tow most days was thinking 50hp stix's would do. Just want to make sure that I wont be adding a bunch more heat. Option 2 was an MP8 but being the tnt adds pressure wasn't sure if I would get much out of it.
Snapoff Oct 6, 2008 12:01 AM
With enough air Flux 2.0's should be good for around 700Hp.
I tow anything I want with Flux 3.3's (775ish Hp), but I have a well matched twin set and I tow cautiously.
If you are going to BD dyno days you could meet Malcolm Cross. He tows 18,000 plus pounds with Flux 2.5's with the BD R-700 (over 725Hp).
Or come to BD and introduce yourself to me and I will introduce you to Malcolm....I have the black stock "looking" truck in the vid.
http://videos.streetfire.net/video/I...ins_176943.htm
Hope to see you there!
