-   3rd Gen High Performance and Accessories (5.9L Only) (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/)
-   -   Smarty Settings (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/smarty-settings-216051/)
cowboy2526 Sep 2, 2008 10:09 PM
Smarty Settings
I am gettting my Smarty and I am wondering what settings should i run
Franklin Sep 2, 2008 10:10 PM
Depends on how you drive it....I'm running sw#7 on a stock tranny but not for much longer...got a new one coming soon
I would say sw#3
cowboy2526 Sep 2, 2008 10:21 PM
Im getting my sbc 3250 DD on thursday also.
trx Sep 2, 2008 10:56 PM
After your clutch is broken in I suggest you start with the lower levels on the odd numbers such as 3 or 5 then work your way up from there. The odd numbered programs have the advanced timing and the even do not. Watch your fuel pressure on the higher levels as on the stock pump I was able to draw mine down to almost 0. Good luck roll some coal....
MikeyB Sep 3, 2008 07:08 AM
What year truck? Do you have an aftermarket lift pump?
For daily driving I keep mine on level 5, torque management 1, timing 4 and rail pressure 1.
MikeyB
