Someone ease my mind - Rear wheel noise.
I have been "adjusting" my rear brakes lately when I get home by letting it roll back a bit then slamming the stop pedal.
Today I noticed with the truck off that when I stop when rolling back in neutral there is a rubbing/grinding/squeal noise coming from the rear drivers wheel (might be the passenger wheel too but I can't hear on that side) Is that just the drums making noise? They don't do it when I slow down easily. Just when I jerk them by stopping abruptly. Brakes are good, truck stops like a champ. Should I quit adjusting them? |
I also want to note that the engine is off when I hear it.
Just pull a drum and inspect it. It could have a rock in it.
Originally Posted by j-fox
(Post 2079599)
Paging infidel
(Post 2079599)
Could also be a broken spring. |
Originally Posted by infidel
(Post 2079861)
Good advice. Looking is always a good place to start.
And why is it so pronounced when the truck is off?
Well, you ain't got other noises to cover it up. There is a small amount of movement in brakes as they apply. Also where shoes rub backing plate is noise prone. Sometimes sanding the linings and cleaning dust from drum helps.
Don't force brake adjustment. |
| All times are GMT -5. The time now is 02:49 AM. |
