-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   FUEL FILTER (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/fuel-filter-19685/)
stroker Nov 3, 2002 08:04 PM
FUEL FILTER
I HAVE DONE IT ONCE......I WROTE IT DOWN......BUT IT'S MISPLACED SOMEWHERE....SOME ONE RUN THRU IT AGAIN PLEASE........OR JUST GIVE ME THE SITE THAT HAS IT ON THERE.......THANKS STROKE ON
Nov 3, 2002 08:06 PM
Re:FUEL FILTER
what year is your truck
stroker Nov 3, 2002 08:10 PM
Re:FUEL FILTER
2001.5
Nov 3, 2002 08:13 PM
Re:FUEL FILTER
I got a 99 and I belive mine is different then your. I loosen the nut on top and let the cansiter drop, pull the filter out and dump the fuel and wipe the cansiter out. Then fill the cansiter about 60% full with clean fresh diesel fuel, stick the new filter in and install the caniter back on. Truck fires right up.
rich Nov 3, 2002 09:34 PM
Re:FUEL FILTER
Real easy get a 1 1/4 socket screw the cap off, take filter off and put new one on. Check O-ring on cap put new one on if needed re-install new filter and tighten it up. Start truck
Commatoze Nov 4, 2002 07:03 AM
Re:FUEL FILTER
I'm getting ready to change mine. Can you use the square hole in the top with a 1/2 drive extension?
Shovelhead Nov 4, 2002 07:36 AM
Re:FUEL FILTER
No, dont use the square drive hole.
Many have cracked the cap that way. :o
Commatoze Nov 4, 2002 07:40 AM
Re:FUEL FILTER
That figures, put a hole there but don't use it. ::) Thanks for the info Shovelhead.
Nov 4, 2002 08:55 AM
Re:FUEL FILTER
I had to pop the cover off of my filter while it was still in the cannister. Couldn't get it out because of the suction with the fuel, didn't want to drain the fuel and lose prime. OK to do that, it worked. Top popped off with small screwdriver on tabs, and then filter came out with a sucking sound. (I have an '02.)<br><br>Ascraeus
Marine Nov 4, 2002 12:40 PM
Re:FUEL FILTER
Lube up the cap threads and o-ring with a little fuel and it will screw on ALOT easier.<br><br>Mike
chuck3 Nov 4, 2002 07:06 PM
Re:FUEL FILTER
Be careful putting the cap back on its real EASY to get it crossthreaded. ;)
nogas Nov 5, 2002 03:52 PM
Re:FUEL FILTER
http://www.dodgeram.org/tech/dsl/maint/3rd_Gen-24v.htm<br>I used these instructions and they worked well. Did mine last night.<br><br>Ron
