conversion cummins to ford with a dodge cab
well i'm starting my conversion.which is strecthing a 85 ford cab and chasis 4x4 duallly and putting a 82 dodge crew cab on thatand putting a cummins in that. i have the frame and the cab -1 rear door (drivers side) and i have the 92 cummins with a getrag plus i just bought a industrial cummnins core(has a bad crank and no water pump) rated at 152HP with no afc on the pump.
so i need to find a water pump, whats a good place to find one? and what should i expect to pay? i also read that there is an upgraded heater core for these 92 dodge trucks? if so where do i find one? would it be better to run the industrail injection pump? also the 92 has upgraded injectors but i dont know what they are. |
Sounds like a good project, but if you weren't going to 4x4 I'd stay with the dodge crewcab chassis. Inspect it when you get the chassis off, it is very beefy
Most any parts store can sell you a water pump.
Don't use the industrial injection pump. |
the water pump should be around $30
what is different about the industrial injection pump/why shouldn't i use it? just woundering, i will use the stock cummins one.
i would even stick with the dodge frame if i had wider runing gear. |
Originally Posted by pwrtripls1
(Post 1993543)
yes the pulley comes attached to the water pump.
you are using a ford chassis with the dodge body. right? |
yes ford chassis with dodge cab
haha cool conversion havent seen one yet.
the fun part is the frame strech ford is standard cab and the dodge is well alot longer. but i have a cnc plasma and torch so the fish plates will be easy.
trooper thorn may have a door to sell you off his spare parts.
thanks, i pm him. i hope to see his convertion driving around salem soon.
is there a way to get better heat out of the heater core. i need it to clear all the windows or at least most of them |
also it will be a hoist bed, and i going to run stacks
Originally Posted by Alwaysworking
(Post 1994459)
| All times are GMT -5. The time now is 04:35 AM. |
