-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   Steering Box going out! (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/steering-box-going-out-193563/)
Megaramasaur Feb 22, 2008 09:13 PM
Well..... I guess I should have investing in a ram assisted steering. My steering wheel started to lock when straightening out after turning left. I drained the fluid out of the cooler lines and res. The fluid was very dark and smelled burnt, it also had small pieces of metal in the fluid. I refilled with new fluid, and its helped, but every once in a while it will bind.... I've lifted the front end and checked for any kind of binding, but there is none, so I'm assuming it's my box???
Any ideas what a new one will cost?
dieselfumes57 Feb 23, 2008 01:09 AM
mine is starting to leak on my 06. i will have to replace mine b4 long
worldindustries Feb 23, 2008 01:13 AM
Is this a common problem in these trucks ?
gnuesse Feb 23, 2008 08:28 AM
I had to replace the steering box in my 06. I think dealer charged around $700.00.
rjm022 Feb 23, 2008 09:03 AM
http://www.redheadsteeringgears.com/
Megaramasaur Feb 25, 2008 09:37 PM
Pretty scary turning and when straightening back out, the steering momentarily sticks.....
How would I check if it's the pump or the box? The fluid was nasty, dark and smelled burnt???
