Does anyone know?
How are the front axle shafts retained? In order to pull the axle shafts out do you have to open up the diff and remove a retainer clip? Or is it retained by the castle nut on the hub assembly. Service manual says to remove axle shaft and thats it. Am I missing something?
TIA Eli |
There are no internal clips. Just the nut on the axle through the hub.
Chris |
Originally Posted by ratlratl
(Post 1956813)
Chris |
http://www.pavementsucks.com/tech/balljoint.php
Can someone explain to me what CAD is that is referenced in the write up link above (first paragraph). I know this is on a Dana axle, but I was wondering if I have to do this with the AAM axle. Once I have the hub off I can just pull the axles out right? Is there a need to lock it in 4x4 before I start? TIA ELI |
Originally Posted by elirandolph
(Post 1957297)
Can someone explain to me what CAD is that is referenced in the write up link above (first paragraph). I know this is on a Dana axle, but I was wondering if I have to do this with the AAM axle. Once I have the hub off I can just pull the axles out right? Is there a need to lock it in 4x4 before I start? TIA ELI CAD is Central Axle Disconnect. The AAM axles don't have it. Once the hub is off, you can just pull the axle out. No need to lock it in 4x4. |
Originally Posted by rams-n-hogs
(Post 1957390)
| All times are GMT -5. The time now is 12:48 PM. |
