lost fuel milage
i have lost about 100 miles to a tank new fuel,air filter i have been getting the fuel at the same place and it started about 5-6 tanks ago i don't know what is going on ???
Re:lost fuel milage
They aren't selling winter blend fuel down there already, are they. I've notice a decrease of about 1 mpg in my last two tanks. I attributed it to refueling at a different stop.
Re:lost fuel milage
gotagoat,<br><br>Do you use a fuel additive? If not, you might try some for 1 tank.<br><br>Things I would check....<br><br>1. Fuel filter<br>2. Air filter<br>3. Lift pump pressure<br>4. IAT sensor<br>5. Map sensor
Re:lost fuel milage
Check you crankcase oil with a Vis guage or have a sample done to see if you have fuel in the oil. You can try smelling it also. Crankcase could go boom, if its full of fuel. Thats the only leak you would not see. Like the other replys, may be the fuel or lack of centane in the fuel that is doing it. <br><br>Dave
| All times are GMT -5. The time now is 04:36 AM. |
