-   1st Gen. Ram - All Topics (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/)
-   -   high idle adjust (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/high-idle-adjust-189804/)
gomerpile Jan 30, 2008 07:51 PM
high idle adjust
ok so i just adjusted my high idle screw almost all the way out, for anyone out there looking for some cheap bang for nothing do it. i can now run gears up to 3000 RPMs with no 366 spring.
third went from staling at 70 to now stops at 82
and od went from stalling out at about 98-100, now i buried the speedo [nonono]and the tach kept on rising[guitar].
also im keeping from the stall out between the 3rd-OD, and boost is up as well.
its just a cheap easy fix, is there anyone out there that can say if theres any damage that may occur from this mod, other than more stupid ideas[coffee]
wannadiesel Jan 31, 2008 05:08 PM
Won't hurt anything. Do the 3200 RPM spring, you are still defueling around 2600 RPM.
