-   3rd Gen High Performance and Accessories (5.9L Only) (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/)
-   -   What kind of rail pressure numbers? (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/what-kind-rail-pressure-numbers-184563/)
wildchild97 Dec 28, 2007 05:44 PM
I just got a new quadzilla RP gauge and i was wondering what kind of numbers i am supposed to be seeing?
53 willys Dec 28, 2007 06:07 PM
with X2 Race I get 6,900-7,500 at idle......WOT I get 27,700 witch seems a little high to me???
duallydave Dec 28, 2007 07:10 PM
it says on theier site will raise presure to 27k.im intersted in how you have over 7k at idle,i only see 5k and 7-9 cruising,havent had her wot yet,too much snow here,whats a beta x2?is it diferent tuning than we get?maybe you have increased presure at idle to get beteer throttle responce,i want it toooooo hahahahaha
wildchild97 Dec 28, 2007 07:21 PM
I am seeing anywhere from 6,900 to 7300 at idle and 24,500-25,000 @ WOT
Timinva Dec 28, 2007 07:32 PM
The 03-04 555 motors run a lot less press from the factory then the 610 motors. My 04 idles about 5200lbs and my 06 has about 7500 lbs. Cruising down the road at about 65mph the 04 runs 12-13k , the 06 18-20k and at wot the 04 is about 22k and the 06 25.5k. All this goes out the window with a press box. Your gauges are no longer accurate around 27500. Tim
