-   1st Gen. Ram - All Topics (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/)
-   -   Leaking Lift Pump (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/leaking-lift-pump-18436/)
christinyou Mar 14, 2003 12:09 AM
Leaking Lift Pump
I was just wondering....does the lift pump start leaking before it is about to go out (as in a water pump)? I just noticed that mine has started leaking and was wondering if it might be fixing to go. I just had a new injector pump installed and it has started leaking since then. I really started noticing it after I installed new fuel filter and manually pumped fuel to fill it (about 30?? pumps). <br><br>Thanks for any info....
christinyou Mar 14, 2003 01:29 PM
Re:Leaking Lift Pump
I found the answer to my problem....it does have a weep hole and will leak fuel if the diaphragm is leaking (Please tell me if this is wrong.) Gotta go get one. Thanks.
RCW Mar 14, 2003 03:43 PM
You are doing the correct thing, once they seep they are history!
