-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   part number for cam sensor? (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/part-number-cam-sensor-183678/)
j Dec 22, 2007 10:42 AM
anyone have it? dodge or cummins part number? i did the search and got 10 results, none of them had the part number. i checked online and couldnt get a part number that was from dodge or cummins. anyone have a good source for these? may try cummins on monday if they're open.
redeyedracer Dec 23, 2007 01:45 AM
do you need a new one???have you read about the possible short located behind the AC comp and near the cam sensor plug??if ur getting a CEL for the cam sensor, this could be the problem...
CD in NM Dec 23, 2007 09:32 AM
I'd take a look at the cam sensor plug first as redeyedracer has suggested first. Then I'd weigh getting an aftermarket sensor over a stock one, could save you a few bucks AND then you'd have adjustable timing.
CD
j Dec 23, 2007 01:16 PM
yeah i looked at the harness. seems that it has already been covered with tape and i added split loom wiring cover to it...
whats the advantage to adjustable timing CD? doesnt my quad box do that? or am i missing something?
CD in NM Dec 23, 2007 01:27 PM
Hey j.
Yes, the quad box does do timing. I was thinking from a stock point of view OR if a box had a little too much timing you could smooth it out, or if you stacked boxes, again smooth the timing out. Plus, the aftermarket stuff is less expensive than the dealership stuff, and many times actually better.
CD
j Dec 24, 2007 03:40 PM
good point... i'll check some aftermarket sources. anyone know what years are the same as mine?? like 03-06 all the same or are they specific?
