-   3rd Gen High Performance and Accessories (5.9L Only) (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/)
-   -   VA 3.2 stack?? (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/va-3-2-stack-158546/)
haildog Jul 4, 2007 02:09 PM
VA 3.2 stack??
Ok guys I've had the VA 3.2 on my truck for the last 110k miles, and its been flawless so far. But I'm looking to up the power "mainly from off idle to 2000rpms". My current box does great but it seems to me it lacks a little in the lower rpms. So whats your sudgestions, stack it with something or sell it and put something new on. I don't tow much but when I do i have no problems turning whatever I get off to maintain EGT's. Thanks in advance.
CG98x Jul 4, 2007 02:50 PM
I liked mine stacked with an EZ. It perked it up nicely where you want, but it did smoke more. Any pressure box should do what you want but watch your egts.
haildog Jul 4, 2007 03:10 PM
What settings do you run your EZ on with day to day driving. I figured a simple pressure box would be the thing, but might as well see what everybody else has to say. Thanks
Dodgezilla Jul 4, 2007 04:02 PM
It stacks well with a Quadzilla box too but if you turn them both up you may see some high egts. I ran that stack for a while in my old 03...
stock03 Jul 4, 2007 04:11 PM
Yup, not much low end.
I had a TS Ramifier stacked, but it smoked too much. However, the low end was a lot better. If I do decide to stack again, I'll probably go with Quad or EZ. But I'm going to try not to add any more "power" to the truck.
Dodgezilla Jul 4, 2007 06:20 PM
Ya, I'm trying not to mess with my 07 either. I'm not having much luck.....[duhhh]
haildog Jul 4, 2007 06:57 PM
Yea I may start looking for a quadzilla xzt. Thanks for all the input guys.
B.Law Jul 4, 2007 10:37 PM
I had the EZ on 50hp and the VA on 70hp. That combo seemed to be very smooth, and the EZ gave it a little more umph of the line.
duallydave Jul 4, 2007 10:41 PM
i will reply soon,i just bought a used 3.2 on here to stack with my predator.it hasnt arived yet but when it does ill post,i got rid of the powerpuck,didnt make much dif when the tuner is on extreme,hope the 3.2 does.
trik396 Jul 4, 2007 10:54 PM
I run the VA3.2 with my Predator. On the 70hp setting I made the rwhp in my sig. When I turned it up to 130hp, I lost a couple. Draining the rail I think... I'm trying a few different things and some H2O and I should easily break the 600mark...
gdh11 Jul 5, 2007 04:47 AM
I run one with a Bully Dog Downloader and a TS MP-8.
haildog Jul 5, 2007 03:30 PM
Thats some pretty impressive #'s you laid down. Thanks for all the input guys. You know how that HP bug is.[duhhh]
trik396 Jul 5, 2007 04:01 PM
I know it all too well.... it consumes most of my thoughts thru the day... $$$
[coffee]
Homer S. Jul 5, 2007 07:50 PM
The xzt and 3.2 seem to play together pretty well on mine.
trik396 Jul 5, 2007 08:38 PM
The VA3.2 is pretty good with just about anything. Good, solid, reliable, smooth power. It's like the underdog that no one talks about. I really like mine...:cool:
