-   1st Gen. Ram - All Topics (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/)
-   -   alternator not charging (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/alternator-not-charging-156016/)
mwolfe Jun 18, 2007 08:01 AM
i have a 1992 dodge diesel and the alternator does not charge, i have two alternators and both are good , also can not get any data out of computer any help would be appreciated. thank you Mike
nweaver916 Jun 18, 2007 12:22 PM
I think the 92 has the seperate voltage regulator? something like that, iirc it's a doghouse shaped unit on the firewall in the engine compartment.
I think it's built into the alt on the 93's (at least I couldn't find it in my truck...but the 'lectric is a mess in that one)
mwolfe Jun 18, 2007 12:24 PM
this truck does not have a external voltage regulator
John Faughn Jun 18, 2007 12:29 PM
The regulator is in the computer , but rarely goes bad .
Get a wiring diagram to look for fuses , fusible links , grounds - these are the most comin charging problems , do not for get to keep the battery cable clean .
Some guys put in an external regulator , I would only do this if the computer is bad & a cheap replacement is not available .
EClancy Jun 18, 2007 04:58 PM
id install an external voltage regulator ($17@napa) and be done with the factory stuff
wannadiesel Jun 18, 2007 05:22 PM
Check the crank sensor and the wiring to it.
