Injection Pump Timing
I have a 1995 with a 4" exhaust, cold air intake, 90hp torque plate, 50hp injectors. I have the injection timing stock. What would everyone recommend that I advance the timing to? I have heard that if you go past 17* you can have problems with the stock head gasket. Also, what are the advantages of advancing the timing? Is it power, lower egt's or what? Thanks
Set it to about 16°
Read more here http://dodgeram.org/tech/dsl/FAQ/timing.htm |
| All times are GMT -5. The time now is 12:47 PM. |
