-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   What Type And Weight Oil For 07 3500 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/what-type-weight-oil-07-3500-a-124512/)
trucksalesdave Nov 18, 2006 07:56 PM
JUST BOUGHT NEW 07 3500....WONDERING WHAT TYPE AND WEIGHT FOR THE REAR AND IS ATF STRONG ENOUGH FOR THE G56....i HAVE HEARD THAT THEIR IS PROBLEMS WITH THE G56 MAIN SHAFT.....SOMEONE FILL ME IN. THIS IS MY FIRST DODGE WITH THE 5.9......IT IS ONE FINE ENGINE.....G56 TRANS IS GREAT TO.....MY TOYS ...07 3500...03 SUPER DUTY....98 S-10......01 VOLVO TRACTOR.....07 SUNNYBROOK FIFTH WHEEL.......07 3500 TO REPLACE MY 01 VOLVO TRACTOR........TRUCKSALESDAVE
rockcrawler304 Nov 19, 2006 10:52 PM
First off Welcome. (and please turn off the CAPS!!) At first you should stick with reagular dino oil like Chevron Delo 400 or Rotella T40. I use the Delo400 myself. I did my first change at 3500 miles along with the fuel filter, just to give myself the piece of mind.
As for the G56, I have not had to change the fluid yet, but I will be going back the the OEM stuff as of right now. I might try something different when the time comes. I think the only problems have been because the trucks were used for truck pull competitions IIRC. Normal use and the standard heavy towing will be no problem.
trucksalesdave Nov 20, 2006 03:28 PM
Thanks...rockcrawler......this being my first dodge and wanting to buy the old style 5.9 and a good stick shift before they mess up a good thing ( 5.9 vs 6.7) . Maybe it will turn out much better for dodge than the ford mess (7.3 vs 6.0). I still like ford but they are in a deep hole as for as the powerstroke engines.....it remains to be seen if the 6.4 or is really a 6.0 with a new decal is any good. I still own a 03 P/S with a 7.3 but it would not pull my new fifth wheel because of 13.800 wt....or it would not pull it like I want it to pull....said my wife....been around many 5.9 trucks that had 300 to 400,000 and still running with the big dogs in the trucks that i sell......trucksalesdave....georgia
Luke S Nov 20, 2006 04:06 PM
I'd have to check for sure, but I am pretty sure the G56 does not take ATF?
singleturnout Nov 20, 2006 05:25 PM
i think it takes ATF+4
trucksalesdave Nov 20, 2006 07:59 PM
Yes the manual does say to use the mopar ATF in the g56.....a little thin in my book....Amsoil makes a full syn. 5w30 manual trans oil that I have been reviewing after I get some miles on my toy.....ON the other hand dodge just might know whats best for their g56....My motto...Modify Everything....trucksalesdave....georgia
