Thread Tools |
the tank should NOT be pressurized! the vent is probably plugged
__________________
01 3500 ho 2WD;4 inch exhaust bully dog stage 3 inj edge comp(removed hybrid hx 35/40 8/25/04) dyno 419.2 hp 891.8.torque w/stage 2`s on a dyno jet 6/25/03 ,htb2 turbo installed 8/25/04, not a dually any more,conversion done in 04... added home designed propane march 07 (to improve mileage) new vp 44 from industrial injection 3/july/07 181000 miles, removed stage 3 injectors ,reinstalled stage 2 to try to control EGT's better.new head gasket by industrial injection 17 dec 2010 |
have you checked the fuel cap?
might not be venting..but that might be only part of the problem? could the fuel lines that come out of the tank be leaking too? -dkenny
__________________
'99 dodge ram 2500, 4x4, auto. 4" mrbp turbo back, Air Dog 100, fuel pressure, boost and EGT gauges '06 jeep liberty '84 Detroit diesel 8.2L turbo..blue bird school bus->no longer. tranny died(4/11) |
I had to replace my fuel pickup and lines due to corrosion in my 99. Return line could have a pinhole in it allowing fuel to leak, puddle and run down side of tank
I'd check the fuel cap to make sure it is working correctly.
Simple stuff first....
__________________
Kurt 2001.5 2500 QC LB 4WD H.O. 6-SPD SLT Plus 3.54's, Camper/Tow/Plow, A.R.E. Canopy w/ SS Vanguard rack, Southbend clutch and hyd.,TIMBO APPS, BHAF/Heatshield, MBRP 4" TBE, FP Gauge, Femco E-Z Drainplug, DSS, Thuren Trac Bar, 2" leveling kit, P/H Tow Mirrors, PBR, 128K miles. FASS LP "When I was younger I could remember anything, whether it happened or not." Mark Twain Support Our Troops! NRA, MSBL, BYO, GSP, BOLTS, Southpaw, CDC* *Cracked Dash Club |
Potentially two things going on here. One is that your fuel tank is probably not "pressurized" but actually what you're hearing when removing the fuel cap is a "vacuum". There is nothing to create pressure in the tank but removing fuel will create a vacuum if the fuel module vent isn't working or is caped. I believe the fuel cap isn't vented because the tank is vented. And its not terribly uncommon to hear someone who has a truck where the fuel module vent cap was never removed on the assembly line.
Also, if you look on the fuel module, amongst all the other lines and wires, you'll see there's short rubber line pointing up (about 1.5"-2" tall) thats caped. I'm not sure what this is even for but its prone to cracking and the sloshing fuel will easily escape and cause a leak on top of the tank. If you're not seeing fuel drip while the engine is running then its not related to the fuel supply or return lines.
__________________
'01 5spd. 4x4 Sport shortbed, 285's, EZ, aFe intake, no silencer ring, straight piped, ISSPRO EV pyro/boost and FP all on pillar, Westach Transmission/Differential temp gauge in dash pod, Raptor 100 and Big Line kit to VP, Pac brake, 2 lo kit, Rancho RS9000X's, 2" leveling kit. |
| Thread Tools | |
