powerstroke intercooler install questions
so im planning to install my PS cooler in a few days. since my truck is a 91.0 i have no cooler right now. i have a new turbo with the elbow. i got a 24v intake off of ebay for $1. i dont have the intake yet.
what size piping are you guys running? is the 24v intake size the same as the turbo elbow? anyone run a straight cool side pipe with a 45degree coupler on intercooler and a 24v intake? (seems like it would work) i dont have my intake yet and to minimize downtime id like to order all my connections OH! and i will be swapping to a intercooled radiator support and radiator thanks!!! ![]()
__________________
91.0 W350 SRW LE. 727 3.54s, Dana 80 LSD, 265/75R16E, 366 spring, THIN pin, pump maxed, what starwheel? timing bumped, BHAF, 3.5" straight pipe, rear bagged, Isspro gauges, Hella H4s, Borgeson shaft.... 96' Saturn SL1 base w/ AT AC CC |
im in the process of doing the swap. i bought 2nd gen plumbing and a friend has giving me a 24v intake horn. i bought a hump hose and a 45 for the engine side. the problem is the horn has a weird angle so it screws things up. also my piping is a hair to short....
for what it is worth i wouldn't buy your stuff from frozenboost.com their couplings are to short in my opinion and after i bought i "real" hump hose the difference in quality is significant. Im most likely going to have to buy all new couplers for the added length.... other people will chime in
__________________
1992 w250, 366 spring, getrag, boost pyro gauges, fuel screw all the way, denny-t pin, hx35 12cm |
The problem is getting hump couplers in reducers. I'm going to use exhaust pipe for the tubes and I'm pretty sure they don't make 3.25inch tubing. Where do you recommend I buy from?
__________________
bump? i need to get my truck back together asap. my intake horn will be here on tuesday so id like to order couplers on monday. thanks!
__________________
Bradshaw is right on the short frozen boost stuff. That is what I am running and they are short. I made my own pipes so the length was not critical.
__________________
89 W250, powerstroke i/c, 3 turns smoke screw, 1/2 turn starwheel, full power screw 4 or 5 turns, autometer phantom boost and pryo, 4 k isspro tach, 727 tranny, 3.07 gears, factory l/s rear, S300 turbo, stans exaust, wish list, T/C, sticks. 93 w250 extended cab, rag, 6X16's, GDS 60mm, full set isspro gauges. |
Okay so can anyone recommend another place to buy them? What size piping are you running with the PS cooler
__________________
Im running 3 inch stuff.
__________________
mabey try these guys out http://store.airflo.com/rubber-hoses---clamps.html
Havent bought from them yet, looks like they got alot of stuff I'll be needing soon. Stu
__________________
91 4x4 manual...stocker,1/8 timing bump, fuel screw 1 turn(what a diffrence) Coming soon- 08 351 VGT full manual control, 4" exhaust, 03 IC or air to water IC. Have tools will FAB! |
Sweet thanks. Anyone know if the 24v intake horn is the same size as a intercooled H1C intake elbow? I'd like to order my couplers ASAP
How did you get a lip in the piping to keep the couplers on?
__________________
I just took a mig and welded a bead all the way around the pipe. Don't quote me but I believe the stock 1st gen cooled horn is 2.5 inch and all the second gen stuff is 3 inch. SOMEONE ELSE KNOW FOR SURE?????
__________________
You got it.
__________________
Dave 386 HP/774 TQ on #2 only, 408 HP/844 TQ w/ water/meth - needs more air! "Butterscotch" - '82 Mercedes 300TD KDP body count: 72 |
I measured my turbo but I have no clue what the 24v intake horn is. So 3inch for sure? I'd like to order my stuff so it ships out by monday
__________________
i was going to try extreme psi
__________________
for what its worth their is a 2nd gen turbo elbow for sale in the classifieds section.
__________________
PM sent bradshaw
__________________
| Thread Tools | |
| Display Modes | |
