| View Poll Results: What are your max egts? | |||
| <1000 |
5 | 5.05% |
| 1100 |
15 | 15.15% |
| 1200 |
14 | 14.14% |
| 1300 |
12 | 12.12% |
| 1400 |
18 | 18.18% |
| 1500+ |
38 | 38.38% |
| Multiple Choice Poll. Voters: 99. You may not vote on this poll | |||
Thread Tools | Search this Thread | Display Modes |
#1 | ||
Post your max preturbo egts
__________________
David '02 3500 dually: Smarty/ tst ce/ mach4/ super 62/ helix 2/ 12mm arps / II Pump/ diaphragm sprung hub 3250 SBC dual disk 543/1040 uncorrected 1/12/08 |
#2 |
1100-1150 is the max I've let it get. I don't think I'll ever let it get above that either.
__________________
"The Beast" 1978 V-Dub MK1 Wabbit Diesel, 4spd, Pump Tweaked, 87k Original Miles ***R.I.P 2002 CTD 4x4 Hand-shaker 374hp/915tq*** U.S. Navy Seabee Veteran We Build, We Fight, We Drink More Beer! |
#3 |
Registered
i can peg my guage REALLY easily
#4 |
Stock first gen? Around 1000.
#5 |
is this pre or post turbo? pre will be a lot hotter
__________________
JESUS SAVES! 1998 Dodge Ram 2500 QCSB 12v 5-Speed 4x4 3.54 gears - SDX 5x.012, S300G Turbo, Custom Fuel Plate, pull cable shut down, 4" straight pipe, GM 1 ton wheel cylinders, other stuff... sold...2006 Dodge Ram 3500 4x4 6-Speed QCLB / 1997 Dodge Ram 2500 4x4 Auto CCLB / 1993 Dodge Ram W250 4x4 Auto CCLB / 2002 Dodge Ram 2500 4x4 6-Speed QCLB Founder INDTR #29 |
#6 |
Post turbo
id say about 900 on the pyro, add about 400 for pre turbo (not sure on how correct that is) and id say 1300.. Tx
__________________
05 3500, smarty, intake, exhaust, full replacements, full hitches, muds, steps, 110 gallon auxillary, R&K toolbox 95 5 spd 4x4 HUGE thanks to Gomer (Ad removed signature violation) |
#7 | |
Quote:
#8 |
1300° is usually the time I get out of it.. Without the SAII... Add 150°F for sure.
__________________
97 2500 4X4 LWB CC SLT Laramie 5spd LSD 3.55. Isspro EV's pyro/boost, #10 Plate, PEAK 3K GSK, AFC Spring, DDP III inj, BD Super B Special Turbo, PEAK IC Boots, TAG III, South Bend 13-1.25" Con FE clutch, SCOTTY II-UNI, MBRP XP 4", KDP Tab, 16° Timing, SS DSS / 03TBK, Roda Deaco PAS. Espar D5WSC heater. B-Quiet sound deadening inside. Dyno 09-2009 405 RWHP / 1050 Ft-lbs '08 2500 4x4 MegaCab Laramie, 6.7L BlackTEC, 68RFE, 3.73 LSD, Smarty S67-ME, MDKRam air. Alberta Chapter #5 Prez... |
#9 |
1250* at 117mph sustained.
#10 |
I've hit 1400* a couple of times for a brief couple seconds at the drag strip. Other than that I never see it go above 1100*
~Nick |
#11 |
With the home made twins the needle stops at 1300 when I was running just the 35 it seen 1650 and still climbing this is with the same amount of fuel.
__________________
97 3500, 4by4 scotty11 5''straight pipe #0 plate 4000k gsk, Lazer Cut D.Vs, PDR 370s ARP head studs twins hx35/12-ht3b/26 3''body lift 2''leveling bilstein 5100s up front pro comp 9000s in the rear gauges meth inj.espar engine heater. 2wd low kit.high idle kit.onboard air, SB 13fe, 255/70-22.5 |
#12 |
Guage is pegged while sled pulling.
#13 |
I've had very, very brief spurts (maybe 5 seconds) up to 1800*. I think I've only done that twice.
I regualry let off of it at 1300* although I have pushed 1400* for about 30 seconds more than a few times while smoking an uneducated ricer!
#14 |
I back out around 1200 'cause I've got the weenie early style head
__________________
90/97 F350 4x4 SRW Crew/long Fummins |
#15 |
I can get mine to 1500 in a hurry. I never hold it there more than 2 seconds at a time. I sure hope a 4" will help at least take it a little longer to get to 1500.
__________________
02 QCSB 2500 4X4, 192K, 5 spd, BHAF, 4" exhaust, Boost/EGT/FP gauges, Edge comp (no fuel wire!), Walbro 392. |
| Display Modes | |
