Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 12 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 05-13-2010, 07:36 AM   #1
4969joes
POLL: What does your egt guage read when you are driving 70 with no trailer?
Im seeing what everyone is getting for egts when driving 70, if you could include egts for uphill, downhill, and level ground at 70 mph, thanks
__________________
97 12 valve 4x4 5 spd, 3.55, 3 inch level with add a leafs to match, bhaf with outerwear cover, 4 inch mbrp, phat shaft 62/65/14, ddp2's, A-1 head studs, ats exhuast manifold, 3k gsk, 60 lb valve springs, bd intercooler boots, autometer guages, #100 slid part way forward, 17* timing, AFC spring kit, kdp tabbed, con ofe, mag hytec rear diff cover on dana 80, new moog front end
4969joes is offline   Reply With Quote
Old 05-13-2010, 08:47 AM   #2
rebal
rebal's Avatar
650 +-at 70 mph depending on head wind as far as up hill that depends on the grade some grades i hit 900* going down hill? long hill 200*
__________________
1990 W250 bought new in Nov. 89 performance built 727 and torque converter , high miler 800 k kelderman air ride
2001 2500 HO 6spd 4x4, Engine brake ,fass,SBC 4" turbo back exhaust BHAF fluid damper,ARP head studs, DSS, Fast cools. wife says trucks fast enough:(
How many of your rights are you willing to give up before you feel totally safe ?Wake Up People vote EVERYONE OF THE BUMS OUT OF OFFICE!
rebal is offline   Reply With Quote
Old 05-13-2010, 09:20 AM   #3
efbeason
efbeason's Avatar
Most of the time at 70mph with no trailer I see between 600-625* on flat ground. When I hit a hill it will creep up a bit. On a pretty good grade I might see 800*.
__________________
efbeason
1998 12 Valve, Club Cab Short Bed, 4X4, 47RE, Goerend triple disk converter, 155,000 Miles. 4" Turbo-back exhaust, #100 fuel plate, timing at 15*, Volant CAI, wastegate blocked, 3K GSK, 215 injectors, KDP tabbed.
efbeason is offline   Reply With Quote
Old 05-13-2010, 05:19 PM   #4
GoinAndABlowin
I see around 650* on the level at 70 mph . . . about 850 to 950* on long uphills .... and 300* on downhills. Like rebal said, it depends a lot on the wind. I've seen over 850* on the level in a stiff headwind here in Eastern Wyoming.
__________________
'95 2500 Reg Cab. 4x4. NV4500. 4" Exhaust. Leveling Kit. Airbag Susp. KDP RIP. South Bend OFE Clutch. Terry's Tune and Time @ Moonlight Diesel. DDP 90HP Injectors. IssPro Gauges.
GoinAndABlowin is offline   Reply With Quote
Old 05-13-2010, 05:31 PM   #5
Andy505
Andy505's Avatar
About 700-750 goes up to 850 on hills. Long steep hills it can get to 1000-1100.
But I'm at 6000 feet above sea level.
__________________
JESUS SAVES!
1998 Dodge Ram 2500 QCSB 12v 5-Speed 4x4 3.54 gears - SDX 5x.012, S300G Turbo, Custom Fuel Plate, pull cable shut down, 4" straight pipe, GM 1 ton wheel cylinders, other stuff...
sold...2006 Dodge Ram 3500 4x4 6-Speed QCLB / 1997 Dodge Ram 2500 4x4 Auto CCLB / 1993 Dodge Ram W250 4x4 Auto CCLB / 2002 Dodge Ram 2500 4x4 6-Speed QCLB
Founder INDTR #29
Andy505 is offline   Reply With Quote
Old 05-13-2010, 09:18 PM   #6
Robert Rausch
No trailer, 70 mph on level Interstate I see very low EGT's--most times less than 500.
__________________
1995 Dodge/Cummins 2500, ATS Stage IV Trans w/Five-Star converter, TST #6, K&N, Aero 45 Gal. Aux Tank, Pac Brake, Rhino liner, Mag Hytecs, UTE Bullbar, disc-brake Dana 70, running boards,
TripleLok Commander
Robert Rausch is offline   Reply With Quote
Old 05-13-2010, 09:40 PM   #7
Tate
Tate's Avatar
I was pushing 800 degrees all the way home tonight. Going up hill I'll hit 1100 or so. Thats at 3500'.
__________________
'98 3500 4x2 Quad Cab, 24v, 5 spd, 3.55s, CDS 13mm, SDX 7x.012 Injectors, Single S480, Big Stick Cam, FASS, BD Short Shifter, SBC DD, Fluidampr
Alcoa Magnums, GM Brake Cylinders, HID Headlights, DSS
'98 2500 4x4 Reg Cab, 12v, 6 spd, 3.55s, 0 plate, 4k GSK, 18° Timing, SBC DD, F1 370's, GT37R/GTX42R Twins, Fluidampr
Alcoa H2's, Lorado Tonneau Cover, HID Headlights, Espar D5, EMS Hub Conversion
Tate is offline   Reply With Quote
Old 05-13-2010, 10:46 PM   #8
turfguy
turfguy's Avatar
650 to 725 on average
__________________
99 4x4 ECSB!! 24v, 4" MBRP, edge, mild built trans w/ single disc / work in prog.
94 12v 2WD/ K&N/ 3" straight pipe-duals/ 215 hp pump/ATS conv. w. DTT box/ KDP done/ timing @ 13.5/ GM wheel cyl's/ gauge pillar/ #10 plate/Best of 26mpg :-)
95 Ram 2500 4x4 gasser plow truck / gas hog! *CONVERTED to a 12v!!* 4" exh. / 100 plate/ mild tranny build
95 cummins 4wd auto/ reg cab stock/ plow truck
95 2wd auto/ unmolested virgin/ 95,000 orig miles *SOLD*
'90 7up 5.0 Mustang vert 5 spd :-)
turfguy is offline   Reply With Quote
Old 05-14-2010, 04:19 PM   #9
4969joes
I see 850-875 on level ground, as high as 1200 going up hill, and 400 going down hill, i think my egts are higher than most peoples and im not sure what else to do about it, without adding a water/meth system
Old 05-14-2010, 05:44 PM   #10
Robert Rausch
4969joes, maybe your gauge is off. My gauge reads about 25 degrees high at it's lowest reading. What I mean is this--when I get in my truck in the morning and it's about 50 degrees out, the EGT gauge reads 75 degrees. I don't know if that temp differential remains constant over the entire readout or not.
Old 05-14-2010, 07:35 PM   #11
TxDiesel007
TxDiesel007's Avatar
used to see 650-750 or so
but that was many moons ago
Rick
__________________
05 3500, smarty, intake, exhaust, full replacements, full hitches, muds, steps, 110 gallon auxillary, R&K toolbox
95 5 spd 4x4
HUGE thanks to Gomer
(Ad removed signature violation)
TxDiesel007 is offline   Reply With Quote
Old 05-15-2010, 01:45 AM   #12
Tate
Tate's Avatar
Quote:
K-type thermocouples are designed for higher temps, they won't be completely accurate below their specified range. My pyro will read 75 degrees whether its 30C outside, or -30C.
Old 05-15-2010, 12:34 PM   #13
first4age
I wished my guage reads that low. The lowest number is 300 C which is 572 F. It goes up to 1200 C which is 2192 F.
__________________
1997 2500HD CC 2WD, LB, 3:54-Antispin, 5 sp, Cali model - 180 hp, KDP @ 180K, 16.5*, Greddy EGT, #8 plate, 60lbs Ex. Valve Springs (Intake Soon!), BHAF, Reese Titan, Firestone Ride-Rite, 3rd gen rims, Cummins/Jacobs Exhaust Brake, Removed silence ring
T.V. for 1996 Lance Legend 500, Car-trailer & 13' Gregor boat
first4age is offline   Reply With Quote
Old 05-15-2010, 02:05 PM   #14
Rare1
500F with empty truck, mile high elevation.
__________________
1998 2500 SLT QuadCab ShortBed, 12 valve, 2 WD , 3.54 diff with Mag Hytec, #10 plate, boost elbow, TAG II, 3000 GSK, timing at 15* (thank you Clucker), automatic full ATS, TripleLoc, Commander, PacBrake, tow pkg, Rancho 9000, AirLift, 20 MPG around town. LanceLite 8.5' slide in, 3500 lb boat/trailer. Bought it 12 years ago after a 1-year nationwide search. It has gobs of torque, runs great, makes 28 PSI boost if I want it, or just 3 PSI empty on the freeway at 70 MPH and 22 mpg.
Rare1 is offline   Reply With Quote
Old 05-16-2010, 07:36 AM   #15
AllPlay
AllPlay's Avatar
70mph = 650 to 700F for me. Probe is pre turbo.
__________________
1998 Dodge Ram 2500 12V Quad Cab Short Bed 4x4 5speed #10 plate Lunar Pyro and Boost gauges
1986 Dodge Ram 150 Short Bed 9" of lift 38" Super Swampers
2006 Jeep Liberty 65 Anniversary Edition 3.7 Stock for now.
AllPlay is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
