Thread Tools | Search this Thread | Display Modes |
#1 | ||
PO514 Code
__________________
03 Dodge/Cummins SRW 4X4 Q-Cab SO-250hp/47RE Bright White, SB, Kilby Condenser Guard,Big Country chrome nerf bars, Husky floor liners, Husky mud/rock guards,tow mirrors,X-Monitor,KW dust covers,Rancho 9000X shocks, Ventshade visors. Better Built low-profile toolbox, Rear spring spacers relocated for a more level look,Super Dave's tank vent-kit,Optima Red Tops installed. |
#2 |
I heard of that code from the guys in the north. They say it comes and goes every winter. Dosen't really cause a problem. I know for the newer trucks (06'-up) there is a flash that addresses this issue.
__________________
2004.5 Dodge 3500 Dually 4x2 Quadcab, 325/600, 4.10 gears with LS, 48RE, Banks Monster Exhaust, Banks High Ram Intake, ISSPRO Gauges, Fuel Pressure, EGT, Boost, Trans Temp, 3 gauge Pillar mount, single steering colum mount, AFE Stage 1 with PGM7, Amsoil w bypass, Timbrens, Brakesmart,Bilsteins, kinda stock |
#3 |
If it hasn't set the CEL light, don't worry about it. Heck even if it has, don't worry about it. I have been getting this a few times every winter since I owned mine. I just drive it and it goes away. Seems to happen more often when I use the block heater. Check it again in a few days or a week and it will probably be gone. You can have autozone or someone clear it if it bothers you and you don't have a means to clear it yourself.
__________________
CWO4 US Marine Corps 04 3500 SRW 4X4 305/555 Goerend 48RE w/Billet input, Billet Flex plate, Triple disk, 4.10 Offroad package, Rhino Spray-in liner, Access roll-up cover, Step Bars, Billet Grille, Monster exhaust w/Aero 4040, Ultra-lite gauges, Smarty, MP-8, Glacier fuel system, Bilstein 5100's, Firestone air bags, 2 micron filtering, S&B intake, GDP intake horn, HE351. SAC #260 73 Duster street driven 493 ci, 6.0's in the 1/8th 9.62 1/4 so far. |
#4 |
Thanks guys for the replies.
![]() Tony |
#5 |
usually means 1 of 2 things...comes on because of short trips taken with your truck...when it starts to get cold u take a short trip it warms up, then quickly cools..if you make multiple short trips, it sees up and down voltages setting the code or if it keeps coming on your sensor is junk
__________________
04 2500 CTD QC SLT 6 Spd Black Cloud 6" Aussie's, AFE , Edge juice w/attitude stacked w.VA 3.1, FASS 150 91 Hero Chopped, Caged, Solid axle 60's front/Rear, Full Chromoly, Fox 2.0's, 302, atlas 4.3, hasnt moved in 3 years |
#6 |
my truck has had that code from day one. it doesn't cause any problems.
__________________
2004.5 dodge ram 4x4.auto.315/70/17 destination a/t's. fender flares.line of fire.clear cab lights.s&b air intake. dt pro fab control arms.autometer ultra-lite fuel/oil pressure gauges.dual isspro tranny gauges.line-x.fass 95gph.bilstein shocks.donaldson muffler.edge juice/attitude.amsoil bmk-11 single bypass.custom made prerunner front bumper with 12,000lb winch. back up lights.cool down timer.mag-hytec dd tranny pan.dyna-trac lock out hubs.thuren track bar.dss steering stabilizer. h2 rims. |
#7 |
same here. i still get it every now and then during winter but it hasn't effected anything yet
__________________
2004.5 2500 SLT QC 4X4, Auto Trans (yeah I know), 3.73 rear, Graphite Metallic, Trailer and Protection Groups, Anti-slip diff, Electronic Shift-on-the-Fly, Westin Platnum Series nerf bars, Rhino lining, Sirius Plug and Play, BFG All-Terrain T/A 305/65-17E, M/T classic lock 17X9, Taurus PT-111 9mm security system, Valentine 1 V1.8 detector software ver.3.872, Garmin Nuvi w/Trapster |
#8 |
DTR's 'Go to Guy'
The rationality code comes on in the winter when you have the block heater plugged in .That causes the coolant temp reading at start up to be higher than the intake air temp reading. The computer recognizes that as an issue with one of the sensors. There is a reflash to update the computer with new information that will eliminate that code, along with some other small issues too.
__________________
2003 2500 4x4 48RE 3.73 Gear - Silencer laying on tool box!, K&N Drop In Air filter, XzillaraiderII Beta Race and Quad Commander, Autometer Phantom oil pressure guage. Nitto 285 Dura Grapplers , Bilstien 5100 shocks, Walbro Lift Pump, Custom 2 micron Fuel Filter VW is gone! Back to driving to Dodge full time! I'll try to be nice, as long as YOU try to be smart! Support DTR by shopping the online store! DTR members get the best pricing - - 304-952-6896 Link to DTR Store |
#9 | |
Quote:
Definition: ra·tion·al·i·ty (rsh-nl-t) n. pl. ra·tion·al·i·ties 1. The quality or condition of being rational. 2. A rational belief or practice. 3. rationality - the quality of being consistent with or based on logic. Tony |
#10 |
I get that code every winter after driving for a period of time (like for several hours) when the temperature is 55 degrees or less. I just ignore it.
MikeyB
__________________
2003 2500 2wd SWB Quad Cab Laramie, 305/555, NV5600, 3.73LS, Line-X, Westach boost/EGT combo gauge, PML diff cover, Airbox mod, Hurst 6spd Shift ****, Adjustable boost elbow, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake Horn, HID SMARTY Sr./Van Aaken C3.2 |
#11 |
DTR's 'Go to Guy'
The term "rationality", used in the description of codes, is there to describe the reasoning behind the code. Like in your case, the ECM compares the reading of the coolant temperature sensor to the reading of the air intake sensor and the ambient air temperature sensor to make sure that they are all close in readings. If they are not, the computer sets this code to tell the technician to look at all of the related sensors and wiring to find the cause. It isn't saying that one or the other is necesarily bad, pre say, but that they aren't matching for an undetermined reason. They are all within specs, just not matching, so it doesn't know which one to set a code for. The reflash basically tells the computer to either disregard the coolant temp reading in temperatures below a certain temp, or not to look at at all and just compare the other sensors instead. Can't say for sure, but they did change the programming to eliminate this code in cold weather when the block heater is used.
#12 | |
Quote:
![]() Tony |
#13 |
The ecm takes readings from the coolant, oil, air, and ambient temp sensors on ignition cycle to help decide how to map everything to start your truck, the P0514 usually initiates from a block heater being plugged (but not always) in and the ecm seeing vastly different temps between the associated sensors.
This is just an addition to Vzdude's expaination. The accumulative reflash for this may resolve some underlying issues, however if you are not having any driveability concerns with you truck, then you don't need to worry about it, keep on truckin. Tim
__________________
2006, 3500 QC/SRW/LB/48RE/4.10/Inferno red, Mag-Hytec trans and diff cover, Isspro gauges, Quad XZTII, GDP 2 micron kit, Air Dog 100 It's my job to save your butt, not kiss it. |
| Display Modes | |
