Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 2nd Gen. Dodge Ram - No Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 08-30-2008, 04:13 PM   #1
freedomrider
freedomrider's Avatar
Cool Plastic Headlite lenses
Hi Guys: Ever had a plastic headlight lense go dull on you? Well rather than buying a new factory unit, I found a kit by Permatex ( sandpaper & polish) that does a great job of making those lenses clear again. At $16 a pop, much cheaper than buying a whole new lens. Now here's where I start feeling stupid. I tied some Blue Magic chrome polish on the other lens, & guess what? It came up just as bright & clear even without sanding. Just thought I'd pass this on to you guys.
__________________
Black 2001 Ram Sport 3500 cab+ 24valve 4x4 dualy
freedomrider is offline   Reply With Quote
Old 08-30-2008, 04:36 PM   #2
scottsjeeprolet
scottsjeeprolet's Avatar
I use Meguiars on mine and it only lasts about a month then back to yellow lights.
__________________
1999 3500 4X4 DRW, QC, LB, Auto, 4.10 posi rear, 235 85R16 Dunlop RV, S&B Intake, Adrenaline w/Pulse, ISSPRO guages, AirDog 100, BD VB & TCI Maximizer TC, B&M Super trans cooler, ATS Co-Pilot, HX 35/40, F1 Mach 3's for tailgaters to enjoy
Scotte
Maryland DTR Chapter #33
Wanna join? PM me for details.
Find out what's going on in MD Chapter #33 Forums
scottsjeeprolet is offline   Reply With Quote
Old 08-31-2008, 05:52 AM   #3
CarlJensen
CarlJensen's Avatar
What you used has a fine rubbing compound in it. Toothpaste will also polish them out. If they are bad enough you can use 2000 wet paper (wet) and medium compound with a wool bonnet/buffer. Works well. Seal them after polishing with a good wax or clear coat to make them hold longer.
__________________
Retired US Navy Chief, 95 2500 auto, peeling white (junk paint), BHAF, #5 plate, EGR brakes, KDP dead, EGT, Boost and Tran temp gauges. Billet TC, upgraded valve body.Three position TC lockup switch. Timing at 15.5
CarlJensen is offline   Reply With Quote
Old 08-31-2008, 08:49 AM   #4
blackimpala
blackimpala's Avatar
I have heard of the clear coat before but what does that mean? Go to wal-Mart and get clear paint or is there a product called Clear Coat?
Floyd
__________________
96 4X4 Auto, Gauges, Full time power windows, headlight relays, By-pass filter, KDP Done, Lukes Link, GM Wheel cylinders, removed fuel heater, Banks triple disc TC, Transgo Diesel shift kit, Homemade freespin manual lockout hubs w/old school bearings.
I need no stinking chips.
For those who fought for it Freedom has a taste the protected will never know.
blackimpala is offline   Reply With Quote
Old 08-31-2008, 09:39 AM   #5
freedomrider
I think you should watch the clear coat, some products melt plastic. Actually on my truck, there was a thin film that pealed off then they truned yellow I had the truck for 4 years before I had probs, so some kind of clear coat is good.
Old 08-31-2008, 10:26 AM   #6
Dave Miller
Clear Coat is like a clear polyetheylene finish like lacquer to seal/protect the lense.
Dave Miller is offline   Reply With Quote
Old 08-31-2008, 02:12 PM   #7
CarlJensen
CarlJensen's Avatar
Right, I used the poly on mine. Nothing with laquer thinners in it. They will craze the plastic. All you need to do is remove the very top layer of plastic and repolish. Sealing it delays the same thing happening again.
Old 09-03-2008, 11:34 AM   #8
01RAMer
01RAMer's Avatar
Quote:
Is this the same Clear Coat used over paint touch-ups, or are you talking about something else? Do you have a brand in mind?
__________________
01.5 - 3500 Dually 5-speed, 4x4,
Egde Juice w/ Attitude, Banks Exh Brake, Valair Clutch w/Ceramic/Kevlar Disc, SS Track Bar, DSS, MBRP 4in Exh, Fuel Transfer Pump Retro ,2 Whl Low Sw
Reese Gooseneck & 5th wheel Hitch w/ in bed elec connector
Elec Flip Tow Mirror Conversion, Mack Trk Air Horns
37ft 5th Wheel Montana 3400RL, 4 slids, Onan Genset, w/TrailAir Pinbox
01RAMer is offline   Reply With Quote
Old 09-03-2008, 01:32 PM   #9
Dave Miller
Quote:
I have not used anything yet on mine but this Colorbond Clear Coat works on plastic. I used the Colorbond paint on my dash replacement and it is very good paint. You could probably use any Clear Coat from automotive store (Kragens..etc) from the paint section:
http://www.lmctruck.com/ICATALOG/DE/full.aspx?Page=70
Click image for larger version
Old 09-03-2008, 04:11 PM   #10
GFB
GFB's Avatar
Meguiars makes a product called Plastix specifically for this. I polish them up every time I wash the truck. It only takes a few minutes.
__________________
2001.5, 4x4, NV4500, Adrenaline/Pulse, Super B, stage 5 jammers, walbro, 4" to 5" miters, 2" Skyjacker, 315 BFGs, valair 13" OFe, tunes by Alpine and JL.
GFB is offline   Reply With Quote
Old 09-03-2008, 04:12 PM   #11
Dave Miller
Quote:
Great! I'll have to try it.
Old 09-04-2008, 07:41 AM   #12
91rangerturbo
91rangerturbo's Avatar
Yep i have used plastix a few times and it works great. If your cheap like me I have also used GOJO hand cleaner. It has a grit in it and cleans them up rather well also.
__________________
Josh
1999 Dodge 2500
Goerend Billet Auto, 150 Jammers, Holley Blue, HY35, Edge Juice W/Attitude, 6" lift, 37" super swampers, and over 1000ftlbs of torque
1991 Ford Ranger 2.3 Turbo
91rangerturbo is offline   Reply With Quote
Old 09-04-2008, 08:29 AM   #13
gotslicks
gotslicks's Avatar
if you get a metal polishing kit from eastwood,use the soft flapper/buffing wheel (Buff Wheel Ventilated ) and the white rouge compound on a high speed drill .....it will take it off asap and shine em up better than new!
itll take you 5 minutes and your hands wont hurt
__________________
01 2500 4x 5sp 3.55,valair 3600dd, adrenaline w/pulse, farmboy diesel 5", afs big dog walbro fuel system,big line kit,ddp 250hp comp injectors,afe torque tube,top gunz 6" lift rock krawler long arms,20" rockstars w/37s BD SUPER B SPECIAL 458hp 963tqw/xzilliraider new 483hp 1047tq w/adrenaline 62/71/14
gotslicks is offline   Reply With Quote
Old 09-04-2008, 08:32 AM   #14
blackimpala
OK, another tip I read about: cut the little alignment **** off w/Dremel tool and use a jitter bug sander or other sanding device. I haven't done it yet but the next time I will.
Floyd
Old 09-04-2008, 08:58 AM   #15
gotslicks
gotslicks's Avatar
Quote:
Floyd
eeeeeeeeeeeeekkkkkk
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
