Thread Tools | Search this Thread | Display Modes |
#1 |
Is This Pin Stripe Removable?
#2 |
Are you sure it is a decal rather than painted on graphic? Usually those decals will come off with a heat gun, but I wouldn't bet the price of the truck on it.
#3 |
MMMmmmm.... Grits!!
You wonder if the decals are why they put the more burly front bumper on. Not likely painted on, but after they are off I'm sure that there will be a fade difference that will need some attention.
Chris
__________________
#4 |
I've removed decals on two of my dodges similar to that with out any problems. Used a razor to lift the edge of the decal to get it started. Then just took my time peeling it back with a heat gun. The paint looks the same where the decal was. But I figured if it was a little bit off would still look better than with the decals. imo
__________________
98 2500 quad cab short box 2wd 5spd 12valve KDPtab,autometer pyro boost,#11 fuel plate,BHAF,4"MBRP,GM brake cyl |
#5 |
It's clearcoated over... Next truck please.
| Display Modes | |
