Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 04-17-2008, 08:30 PM   #1
Elohim1
Pics of my Engine recent compartment Mods
Tims 3" intercooler tubes
Icebox CAI
Ind. Inj. Turbo
And a pic of My Michelin tire off the M715 for comparison. (had to fix a flat)
Click to enlarge.
Click the image to open in full size.
__________________
91 Dodge,DRW/SWB, 4x4, 6x.013 edms,62/65/14 Phat shaft,Icebox CAI,RS9000 shocks, Autometer gauges,Silverline Stacks,HX40pipe, 3"SS ICtubes, NV4500,DD clutch,NP205,piston pump.
68 Jeep M715, ZZ502/502 cratemotor,Edelbrock MPFI, Rockwell Axles,OEM lockers,Stazworks beadlocks,47" Michelin XML's, PSC Hydra assist/ power steering,Hydraboost,RS9000 shocks,Th400, Np205 Twinsticked, ARB bumper,Mile Marker 12K Hyd.winch,Autometer PhantomII gauges,LED Lights, Painless wiring
Elohim1 is offline   Reply With Quote
Old 04-17-2008, 08:58 PM   #2
mullishacrew
thats lookin awsome!, how was it to do the intercooler tubing?, you should throw them michelin tires on there haha
__________________
1990 w250 single cab, 93 intercooler and rad support swap, nv4500 conversion, south bend dual disc clutch good to 1400ftlbs and 700 hp, hybrid hx35, pumped maxed,1/8th timing bump, ARP head studs, BBD pulse exhaust manifold, PDR fuel pin, 75 hp injectors, BHAF air filter, 8" skyjacker lift and 3"body lift, 385/75/16 toyo open country M/T on eagle alloys , 5" turbo back to 6" CAT stack, big bush bumpers front and rear. (3) KDP killed, Pro Comp traction bars
mullishacrew is offline   Reply With Quote
Old 04-17-2008, 10:58 PM   #3
Trooperthorn
Trooperthorn's Avatar
Noticed your tires (not the big one). I may be going dually on my crew and am concerned about limited tire options. What are you running?
__________________
'77 w200 crewcab, 4x4, 91.5 ctd/nv4500/205, M&H chromoly tie rod. In the works.
'77 Ramcharger/clubcab shorty '91.5 ctd/auto/205, GSK, M&H #2 fuel pin, Guages, 37s on 8 lug 60/70, 16cm, screws turned, cross-over, Jungle frame kit
'91.5 w350 standard cab, auto, 3200 spring, m&h #2 pin, fuel pin maxed (91.5 short pin, 1.5 turns), 315k
'86 Jetta turbo diesel 145K.
Trooperthorn is offline   Reply With Quote
Old 04-18-2008, 04:48 PM   #4
haloman
haloman's Avatar
Looking good!
__________________
Daniel
01.5 2500 CTD 2wd 6spd QC/SB Green SLT
haloman is offline   Reply With Quote
Old 04-18-2008, 05:11 PM   #5
Elohim1
Quote:
Tires are 245 75/R16
Thanks for the compliments Guys.
Old 04-18-2008, 05:12 PM   #6
Elohim1
Quote:
Very simple.
Old 04-18-2008, 06:04 PM   #7
rbrettctd
rbrettctd's Avatar
How do you like that 62/65/14 with the 6x13 combo? Thats exactly what I had planned.
__________________
Randy
The New Rig: '99 QCSB 2500 4wd auto. Smarty, 35/12.50/17 tires, otherwise stock...
Traded:
1991 D250, 7.3 intercooler, DennyT stg 2 pin, POD's, HX35 (14cm), SB3250 DD clutch, custom intake and cooler tubes, SW Fab bumpers, Headache rack, homegrown grille inserts, piston LP
rbrettctd is offline   Reply With Quote
Old 04-18-2008, 08:19 PM   #8
Elohim1
Quote:
I would definitely recommend.
Truck was previously stock. So when I switched it over it was Like day and night difference. I am going to try to locate a Dyno nearby shortly. The truck is not holding in 5th gear right now. So I will have to get that fixed first. Its always somthing.
Old 04-18-2008, 10:39 PM   #9
big stinky
big stinky's Avatar
Steering dampners worth the time/effort/money?
__________________
90 w350 c&c DRW Getrag
Eatin rice and pooin bling
big stinky is offline   Reply With Quote
Old 04-19-2008, 02:57 PM   #10
Elohim1
Quote:
Yes, I believe they are, mine reduced some steering wheel shimmy. Plus you get a "cool factor" along with them.
Old 04-21-2008, 09:43 AM   #11
whereswaldo250
whereswaldo250's Avatar
Quote:
Where did you pick yours up at? Looking good
__________________
BLACK 1992 Dodge Cummins Turbo Diesel-4x4-Standard Cab-9 Speed Rag+Gear Vendors-4:10 d70 limited slip w/ 11 leaf springs!!-167,000...and slowly counting. Mods to date: Rebuilt HTT Stage IV H1C/E 14cm w/g-366 spring-3/4 turn on fuel pin-star wheel bottomed-BHAF Outerwears(filter minder)-AD165 w/ sump-Isspro Pyrometer/Boost/Trans/Fuel 4" Exhaust-Trans Coolers-Buckstop Bumpers
1-24-09: 158hp 408tq (Dynojet)
whereswaldo250 is offline   Reply With Quote
Old 04-21-2008, 08:07 PM   #12
Elohim1
Quote:
Summit racing, they guarantee (I know that spelled wrong) lowest price.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
