#16 | |
Quote:
Those stripes on trailer tires were on trailers I pulled 28 yrs ago from a frieght outfit I worked for & never knew why they were on there. I thought maybe they were on there to let the shop know they were recaps & had already been capped once & ready to be replaced when worn out.
__________________
Tankeryanker Glenn 2005 QC 4x4 nv5600 slt dually, Isspro gauges, Rokktech sensor, few holes in the air box,AFE pro gaurd 7, cool blue hose, MBRP exhaust, pacbrake,new intercooler, Brakesmart cont. 32' Everest 5vr, Bigfoot 10.6 TC |
#17 |
You see them on swift, werner, and j b hunt trailers. Mainly, it's so that the driver can tell if his wheels are turning in the winter. I've seen some doozies driving for those companies as well as the two I've been with.
#18 |
exactly. they paint the tires for the knuckle heads that don't belong behind the wheel of a big rig or anything of substantial weight.
__________________
07 Mega, 9" lift, Toyo's, 8" stacks, Billet Clamps, Smarty, Ravelco, Ice Box, HID's, RECON, Ranger 6900 CB, Sterling grill SAC Member #1 Megacab Club # 81 3rd Gen Stack Club #18 Soldiers for Jesus Motorcycle Club (Prospect status Jan, 30th) NMDTR #44 PM me for details |
#19 | |
Quote:
Lol, if I could name 3 companies with some terrible drivers, those would be it.
__________________
02, 24v, 6 speed, Edge Juice w/ Attitude, BHAF, 5" exhaust to dual 7" turnout stacks, 35" Pro Comp Xtreme AT's, silencer ring removed, 1700 watt stereo, XM radio, CB, Eaton Fuller shift knob, Fuel Boss Mechanical Lift Pump, on board plug in jumper cables |
#20 |
DTR's Toad Wrangler
Ya that paint stops the long double black lines you see from time to time going down the highway.
The paint is also for the driver that has been trained in the use of mirrors.
__________________
94 Dodge SLT 2500, 4x4, 5 speed,dual friction clutch, 100 plate,AFC and plate full forward, A pillar boost and Pyro gauges, 4" exhaust, K&N FIPK with outer wear, Pac brake, Frantz Oil cleaner, Firestone air bags, Rancho 9000 shocks, GM rear brake cylinders, rhino lining, home made DSS and a bunch of stuff that I can't remember |
#21 |
never heard of this on a power unit- we do it on trailers so we can tell if a wheel is locked up
__________________
2002 Cummins 4x4 2500 White 59,000 miles Single Cab Long Box 4'' exhaust with Aero Turbine(resonated) muffler Turbo Silencer Ring MIA BHAF Homemade Heatshield BD Power Low Fuel Pressure Light FASS DDRP lift pump New OEM IP Just bought 2004 Ram 1500 to run back and forth to work. 117500 miles Silver |
#22 |
they are training wheels.........
__________________
Protecting the constitutional principle of the separation of state and church 2006 Ram 2500 CTD QC TRX4 Winterized for Arctic conditions... 2 Heated Battery Pads @ 60 watts each Engine oil pan and Transmission pan heaters @ 150 watts each Engine Block heater 750 watts Bank of 4 Moose Lights on a Randy Ellis light Bar DeltPro 77 gl. fuel transfer tank plus storafe Dueler A/T REVO's with UNI-T AQII Technology For Security...Ruger Red Hawk 44 mag and 11 year old German Shepard/Husky |
| Thread Tools | |
| Display Modes | |
