Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > Performance and Accessories 2nd gen only
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-20-2009, 05:35 PM   #1
CODODGE2500MAN
CODODGE2500MAN's Avatar
P0336 and P1693
I took the truck to get scanned and these are the codes that came back.
I've been told one (I think P0336) is for the crank shaft position sensor and the other is on because of my abs light. Is this right?
Crank shaft sensor is $64. Where is this located? I've been reading on here and some have said that it could just be a bad connection.
Any other ideas?
__________________
TOW RIG - FEB 2010 TOM:
'98 24v LB 4X4 DTT auto, FASS, 4" Str8 pipe, ATS Manifold, AFE, Edge Comp, Boost Trans Pyro Fuel, Posi, Thuren Trac Bar, 285's, 2 15" RF HE2 subs under backseat, In-Dash DVD, Remote Start, Tow Mirrors (always UP), Light up by Recon!!!
TOY:
'93 YJ Wrangler, Dana 44/60, ARB/Detroit, 4.56 37" MTR's Beadlocks, No windsheild top or doors needed! Custom Paint!! FULL CUSTOM ROLLCAGE! Custom Seats. New Custom Dash on the way! All By ME!
PICTURES in Gallery!
CODODGE2500MAN is offline   Reply With Quote
Old 11-21-2009, 01:36 PM   #2
CODODGE2500MAN
Looks like I'll be replacing a Crankshaft Position Sensor.
Who's got a write up on this or knows where I should start?
Thanks...
Old 11-21-2009, 10:22 PM   #3
77machomopar
Send a message via AIM to 77machomopar
fairly easy to do. its behind the starter though. pull the starter and the 10mm bolt holding it in.
__________________
1999 QCLB
4x4 Auto
Straight Pipe
Rebuilt engine @ 112,561
ARP head Studs, Edge Juice/Attitude
Holley Blue/ Stock LP
116,220 mtd
77machomopar is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
