Thread Tools | Search this Thread | Display Modes |
#1 | ||
DTR's Cow Boss
P0237 Turbo/Super Charger Boost Sensor A Circuit Low
__________________
#2 |
Hmmmmmm!!!!!!!!!! You might want to check each battery. One may be going dead. Battery disconnect can erease codes some of the time.
__________________
2008 1/2 3500 dually that is stock except for 2 micro inline filter for fuel. Infero red extended cab, long box made for highway towing. |
#3 |
DTR's Cow Boss
Code came back on an ran like a paper weight on the way home tonight like it had no boost. Could the map sensor be going out? I had been working on the lift pump and noticed tonight that the plug into the map sensor was a little bit out and I pushed it back on and the cel like is off. If it was my injector pump would it not re prime once I open the fuel system up when I changed the lift pump? If any thing after pushing the deal back in I will run it and see how it does if not I might need a new map or boost sensor as when its off it runs like a raped ape. My fuel psi is 15psi idling and nothing below 10 on it hard and on a side note each battery is good checked with my multi meter and at the tire store.
#4 |
I had the same code flash up on my truck last year. Truck ran like a lead block. After shutting it off and running a few miles it went away so I could make it home. Cleaned my map sensor and never had the problem since. But as soon as I got home I called cummins and ordered up a new sensor. I didn't put it on till this past feb. So for close to 10 months my truck ran fine after having that code. You could try cleaning the MAP sensor to see if that helps but I would get a new one just to be sure nothing goes wrong.
__________________
Matt 2002 Dodge Ram 2500 4x4 SLT Laramie 24v Cummins Automatic with 4.10 LSD "Arrest Me" Red Regular Cab Long Bed. Quad XZT+,Amsoil BHAF,Gauges,4" straight pipe w/ 5" S.S. tip 2008 Dodge Ram 1500 QC/SB White 2wd Hemi, all stock except debadged "There isn't a thing in the world a man can't fix with a thousand dollars and a thirty ought six" April 2009 TOM Winner! |
| Display Modes | |
