Ovate in the horizontal plane
Old 08-28-2009, 03:04 PM
DTR Advertiser
Don M's Avatar
Coming soon. more details in the coming weeks/months. Testing ongoing.
NICE RESULTS.
Now back to work.........
Old 08-28-2009, 03:06 PM
torquefan's Avatar
Trajectory with enhanced postulation?
Ok, ok, I'll wait until the rest of the story comes out.
Old 08-28-2009, 06:56 PM
Brian Lent's Avatar
Uhhhhhhh. Good job!
Old 08-28-2009, 07:31 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
Sweet
If this improves variable socialization at the flamitistan level, we should see optimum increase in gonator efficiency...... or more to be precise!
Old 08-28-2009, 10:03 PM
trik396's Avatar
I'm wondering if this has anything to do with the knuten valves and variable plasma quazars.
Old 08-29-2009, 06:32 AM
MikeyB's Avatar
Ooookay..... Well, it was Friday afternoon and close to beer thirty!
MikeyB
Old 08-29-2009, 07:04 AM
Administrator/Jarhead
madhat's Avatar
No, he's just got something new, and trying to rile us up.
I hope it's a flux capacitor for diesels...
Old 08-29-2009, 08:08 AM
mikmaze's Avatar
so long as it renders the truck in the other lane useless, I'm all for it
Old 08-29-2009, 08:40 AM
megacabdad's Avatar
Finally...!
Old 08-29-2009, 08:51 AM
mikmaze's Avatar
hmm ovate........... oval.............. horizontal plane............ no more round holes in the tips, oval, to shoot more fuel horizontally across the top of the bowl...........
Old 08-29-2009, 09:21 AM
DTR Advertiser
Don M's Avatar
We have a winner!
Round holes are the most efficient in most folks view, but the oval hole design does a couple of interesting things. Firstly it helps the fuel stay in the bowl. As these injectors get larger the spray holes are getting larger too.
The oval hole is wider rather than taller and this gets us the higher flow without the fuel spraying as much up on top of the piston.
Second, the wider pattern is lowering smoke. The early results seem to point toward more fuel burning in the leaner regions between the spray jets. This area is larger with a round hole VS the ovate style.
The ovate hole design is difficult to produce with high accuracy so currently is only being tested on the Flux 4 and up sizes. I think we have a winner here. The air/fuel mixing is very much improved.
Old 08-29-2009, 09:56 AM
mikmaze's Avatar
nice, do I win a set of flux 4's ? jk, my truck smokes quite well on the flux 2's thank you very much
Old 08-29-2009, 10:49 AM
Bswope's Avatar
That's kinda what I had in mind after I read it a couple times........
Mike if ya win a set I sure could use a set of flux 2's!!
Don if you need a tester when you start doing the smaller sticks my truck will be available!!
Do you think you will do the smaller ones??
Old 08-29-2009, 01:06 PM
bbbxcursion's Avatar
That's a cool idea!
Old 08-29-2009, 01:53 PM
doug60's Avatar
Things that make you go HMMMMMMM.
Quick Reply: Ovate in the horizontal plane
