Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 2nd Gen. Dodge Ram - No Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 03-02-2003, 06:31 PM   #1
Old Iron
Old Iron's Avatar
Outside temp readout gon nuts
Has anyone had any trouble with there outside temp readout? <br>This one was working fine. Now it reads ok when it is 45 or warmer but it goes nuts when it is colder, it will read in the negtive for a while then bounce around . Is there any calibration for the computer ? I did replace the temp sensor with no improvement. The reading is in Fahrenheit.
__________________
1998.5 Ram 2500 Quad cab 4x4 Black 5.9, 24 valve,Auto, 100%DTT ,Pac brake, BHAF,4" Straight piped, Isspro pyro,boost,fuel pressure, trans temp gauges pillar mount, Blue Chip VP44, Carter P4601HP pusher pump,Smarty,Edge juice with attitude, Don Ms Mac 2.0 injectors,HX35, Gitts leveling and overload springs,air bags,Rancho RS9000 shocks,Torklift hitch,
Old Iron is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
