Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (5.9L Only)
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 03-23-2012, 01:20 PM   #1
cozzo1000
cozzo1000's Avatar
Old synthetic oil in garage.
I have a case of Amsoil from about 12 years ago that I bought to put into a racing car. The car has been sold and I never used the oil. It's Amsoil 10W-30 and it says "Turbo Formulated" on the case. Is this OK to put in my truck? Or is the oil outdated? I don't suppose oil has a shelf life.
Any thoughts or help?
Click image for larger version
ID:	38922   Click image for larger version
__________________
Silver '05 2500 QC 325/610 Cummins, auto, Silverline turbo back exhaust, no cat, no silencer ring, Michelin AT2s, Banks Ram Air CIA, Smarty Jr. & paid off.
2009 Harley Night Train, Lowered, Stage 1 intake, V&H Pro Pipe, SE programmer, 103" big bore, more goodies soon!!!
Colt AR15 SP1, HK-91, S&W 686 P.
cozzo1000 is offline   Reply With Quote
Old 03-23-2012, 01:27 PM   #2
Nate-03 D
Nate-03 D's Avatar
Hoarder much? lol
Just kidding. I've always wondered if oil had a specified shelf life as well. I guess you could send in a small sample for oil testing and see how the results turn out.
I would think after sitting for so many years something inside must start to break down?
__________________
:Truck:
*2003 SO, 47re
:Performance:
*Smarty SR
*Dr. Performance Stage ll
*ISSPRO
*MBRP
*AFE
:Suspension:
*Tuff Country 4" Lift
*35" Toyo M/Ts
*Devino Wheels
Nate-03 D is offline   Reply With Quote
Old 03-23-2012, 02:27 PM   #3
cozzo1000
cozzo1000's Avatar
Yep - that's what I was thinking..... break down. It's also aged technology and might not be good for more modern diesel engines.
Old 03-23-2012, 02:32 PM   #4
Busboy
Because it's sealed I would think it's still OK. You can go to the Amsoil web site and there is a spot to ask questions. As I use Amsoil I have asked a few over the years.
__________________
2011 3500 Laramie CC SB 4X4 Auto 3.73. Reese Cl 5 hitch. B&W turnover & comp. clean oil mod.
2011 3500 SLT CC LB 4X4 G56 SBend DD 3.73. Reese Cl 5, hitch, B&W turnover, clean oil mod. Sons truck.
Busboy is offline   Reply With Quote
Old 03-23-2012, 03:07 PM   #5
Spooler
Spooler's Avatar
It needs to be formulated correctly for a diesel. Gasser oil won't work well in a diesel. It can't suspend the soot in the oil which will increase wear alot.
I see SJ-CF ratings on the bottle. I don't think that is what is required for our engines. CI-4 rating, if memory serves me correct, is more like what you would need.
__________________
2004.5 Dodge 3500 Dually 4x2 Quadcab, 325/600, 4.10 gears with LS, 48RE, Banks Monster Exhaust, Banks High Ram Intake, ISSPRO Gauges, Fuel Pressure, EGT, Boost, Trans Temp, 3 gauge Pillar mount, single steering colum mount, AFE Stage 1 with PGM7, Amsoil w bypass, Timbrens, Brakesmart,Bilsteins, kinda stock
Spooler is offline   Reply With Quote
Old 03-23-2012, 11:09 PM   #6
nickg
nickg's Avatar
I believe S= spark ignition(gas) and C= compression ignition(diesel)
so that oil would be good for gasser not diesel
__________________
Nick
2003 4x4 SB, edge Juice, 08 steering upgrade, bushwacker fender flairs, firestone airbags, Georend VB,BD flex plate,tripple lock TC, tranny by me. Military Mechanic (20yrs)
Definition of a veteran - Whether active duty, retired, or reserve - is
someone who, at one point in his or her life, signed a blank check made
payable to "The People of Canada", for an amount "up to and including my
life."
nickg is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
