Thread Tools | Search this Thread | Display Modes |
#1 | ||
Oil pressure
__________________
1998 Dodge Ram 3500 2 WD Quadzilla XZT 75 gallon in bed transfer tank. Location, 08015, NJ. |
#2 |
usually takes no longer than 5 to 7 seconds on mine to get up to normal pressure on cold start......
__________________
02 2500 QC 4X4 Sport Auto / Carli Coils / Bilstein 5100's / Rokman Adjustable Control Arms / DT Pro Fab Track Bar / Borgeson Steering Shaft / KORE Mini-Paks / FASS DDRP / PML Transmission Pan / Kool Vue Tow Mirrors / EDGE Insight CS / ISSPRO EV2 Electronic Fuel Pressure Gauge |
#3 |
Same here on the 5-7 seconds.
A little longer after an oil change initial start up.
__________________
Kurt 2001.5 2500 QC LB 4WD H.O. 6-SPD SLT Plus 3.54's, Camper/Tow/Plow, A.R.E. Canopy w/ SS Vanguard rack, Southbend clutch and hyd.,TIMBO APPS, BHAF/Heatshield, MBRP 4" TBE, FP Gauge, Femco E-Z Drainplug, DSS, Thuren Trac Bar, 2" leveling kit, P/H Tow Mirrors, PBR, 128K miles. FASS LP "When I was younger I could remember anything, whether it happened or not." Mark Twain Support Our Troops! NRA, MSBL, BYO, GSP, BOLTS, Southpaw, CDC* *Cracked Dash Club |
#4 |
no offense but when you say 5-7 seconds to get to normal pressure.. ??? these gauges are dummy idicators, they dont show true pressure.
__________________
2002 6-SPD LB 4X4 QC BD 64/71/14, SB-DD3600, TST PM3/SMARTY MACH 4'S, RINGED W/ STUDS,HAMILTON BIG STICK,SPRINGS AFE/2 " 5" EXH D/PRICOL GAUGES, FASS 150, FUEL-STRAW, BORG BOX AND SHAFT, DSS-BOX DT PRO-FAB TRAC BAR, 3RD GEN UPGADED STEERING,DUNKS TRACTION BARS, AIR BAGS,17'' KMC'S, 37" TOYO MT'S 6" LONG ARM LIFT.THANKS RIP@sourceaumotive. US.MARINE PROUDLY SERVED 1993-2006 -NO BETTER FRIEND NO BETTER ENEMY- |
#5 |
I don't think the question is as much about whether it is exactly 40 psi as much as the question is about how long until your gauge starts to move upward to the normal position you have seen over the years. Whether they are dummy gauges or Nasa gauges is a non issue when the op just wants to know how long. Maybe it takes 20-30 seconds for his gauge to budge off the peg in the morning so psi and dummies are irrelevant I do believe.
To the OP, seems like mine is probably 5 seconds, but that is just a shot in the dark and something I've never looked at but know it is not very long at all.
__________________
2002 3500 4x4 5 speed, AMSOIL conversion in process, American Eagle wheels, Quadzilla Adrenaline, Dipricol, Fuel Pressure, boost, Pyro, Glacier Diesel Fuel Boss, South Bend 400/800 Clutch "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill |
#6 |
I guess I should of worded different..
the mechanical oil pressure gauge I have reads far faster of movement than the oem dummy gauge. but I can say for the length of time that i owned my early 01 CTD that the oem gauge moved quick almost 2 seconds after start up. except in cold mornings. |
#7 | |
Quote:
__________________
'98 3500 4x2 Quad Cab, 24v, 5 spd, 3.55s, CDS 13mm, SDX 7x.012 Injectors, Single S480, Big Stick Cam, FASS, BD Short Shifter, SBC DD, Fluidampr Alcoa Magnums, GM Brake Cylinders, HID Headlights, DSS '98 2500 4x4 Reg Cab, 12v, 6 spd, 3.55s, 0 plate, 4k GSK, 18° Timing, SBC DD, F1 370's, GT37R/GTX42R Twins, Fluidampr Alcoa H2's, Lorado Tonneau Cover, HID Headlights, Espar D5, EMS Hub Conversion |
#8 |
Next wintry morn set your syrup on the porch for an hour before you flip your cakes, leave one by the stove too and see how fast your eatin....
catch my drift? |
#9 |
I tired what Sixslug said this morning. In case any of you haven't tried, at -30 Rotella T6 pours slowly and tastes really crappy. I think I will go back to maple for breakfast.
__________________
Sean in Dalemead, AB Black 2000 Ram 2500 QC Auto 4WD with CTD, Posi-Lok CAD, DSS and Edge Insight.. |
#10 |
When the temp was below zero I counted to 20 before the gauge moved. I started bumping the engine over till I saw it move after that incident
__________________
94 Dodge 2500 2WD CTD, 5 speed, 400,500 miles. 96 Dodge 2500 SLT 4x4 CTD, 47RE, 175,000 miles. - SOLD (sianara automatic!) |
#11 |
It took 12 seconds this morning, the check gauges light came on for a while. temp was -1 F
__________________
Rick 98.5 2500 QC SB Laramie 24v 5spd(currently 4spd) 4x4 stock 2002 Audi A4 Sport Quattro 5sp |
#12 |
OK, Thanks guys, I don't feel so bad now. Mine takes 6-7 seconds consistently at around 30 degrees. If the sensor is in the cam galley I guess that might explain it. Just makes me uneasy to wait that long for oil pressure. I am going to install a mechanical gauge at the filter and see how long that takes. Mains and rods without oil in a diesel for 7 seconds would not be good. I know a lot of the Ford guys use pre-lubers, anyone here do that?
Rick |
#13 | |
Quote:
HTH Rick |
#14 | |
Quote:
but when the twins get put on I will have to find a new spot to get the reading |
#15 | |
| Display Modes | |
