Thread Tools | Search this Thread | Display Modes |
#1 | ||
Oil Pressure bypass valve?
#2 |
Muted User
Re:Oil Pressure bypass valve?
OK, no problem,<br> the bolt you took out holds the spring that allows a oil bypass piston to relieve excess pressure thru a spill passage. There is an oil pressure piston, a pressure spring, and the bolt that holds it all in.I dont think you overtightened it because the more pressure on the spring, the harder it is for the piston on the other side to release the oil.(making more oil pressure before it bypasses). It is mainly used because the thicker cold oil causes Much higher pressures, it isnt used much when the oil is hotter and has lower pressure.You might try just changing your oil and see if the pressure comes back.<br> I had a railbuggy with high pressure springs in the oil bypass and it BLEW the oil filter apart.Good luck<br> -RATCHET-
__________________
1992 dodge 3500 dually ctd 68,000 original miles hx35w turbo 12cm, 3k gov spring, 4" exhaust 13" k&n cone, Timing adv. 1/8" |
#3 |
[quote author=Guy link=board=9;threadid=12129;start=0#114684 date=1047434533]<br>I just recently swapped engines in my truck. My oil pressure seems to be dropping to about 15psi when my engine warms up. When I was tinkering with this motor, I opened up a bolt by the oil filter that a spring under it. Is that bolt and spring the Oil Pressure Bypass Valve??<br>Is it possible I may have tightened it too much allowing the oil to pass through at a low psi??<br>Does anyone have a schematic of the oil delivery system??<br>[/quote]<br><br>Did you check the oil psi with an external pressure gauge or go off of the one in the dash? If you went off of the dash, I would say your problem is the oil psi sending unit. Mine showed real low oil psi readings, turned out it was just a bad oil psi sending unit. It now reads right in the middle of the guage at highway speeds.
#4 |
Be aware that early B engines had very low oil pressure at idle. My 91 was of concern when new and I measured with a guage as 18 psi idling brand new. Later years had increased flow volumes to give more like 35 psi idling. I think there were a lot of oil transmitters replaced needlessly on warranty because of customer concerns in those early years. Now they give you a guage that is driven by the computer reading mid scale even if pressure is anywhere above 10 psi, like the old "dummy light". Treat the customers like dummys now.
__________________
97 W250 4x4 AUTO (82,000 km), totally stock but KDP tabbed, TC lock disable switch. 91.5 W250 4x4 AUTO, 16cm housing, 185 injectors from PDR, TPS bypassed, Borgeson coupler, (450,000 Km ) - no major work and original tranny. 2000 2500 Quad, Auto, 4X4, Isspro guages, Diablo Puck, TC lockup disable sw. |
#5 |
The oil pressure bypass valve in the engine opens at around 65 Psi. Normal operation at idle should be around 10-15 Psi and up to near 40 Psi at WOT.<br><br>J-eh
__________________
97 2500 4X4 LWB CC SLT Laramie 5spd LSD 3.55. Isspro EV's pyro/boost, #10 Plate, PEAK 3K GSK, AFC Spring, DDP III inj, BD Super B Special Turbo, PEAK IC Boots, TAG III, South Bend 13-1.25" Con FE clutch, SCOTTY II-UNI, MBRP XP 4", KDP Tab, 16° Timing, SS DSS / 03TBK, Roda Deaco PAS. Espar D5WSC heater. B-Quiet sound deadening inside. Dyno 09-2009 405 RWHP / 1050 Ft-lbs '08 2500 4x4 MegaCab Laramie, 6.7L BlackTEC, 68RFE, 3.73 LSD, Smarty S67-ME, MDKRam air. |
| Display Modes | |
