Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-19-2009, 07:19 PM   #1
24Vsporty
24Vsporty's Avatar
NV5600 Eaton filter help?
Dont let the number of posts fool you...I have always been able to answer questions by reading responses to other peoples dumb questions....but not this one.
As per advice on the forum, purchased a Eaton tranny filter that attaches to the PTO cover on the 5600. As usual the instructions are horrible. Is this a "Top" up application or a "Top" down application? What side should it go on...the passenger side?
To explain ill quote the instructions.
"Install the filter with word "top" and the projecting scoop in the top position when oil is thrown toward the PTO opening by the top of the gear. When oil is thrown toward the PTO opening by the underside of the gear, install with stamped words "Top" down.
There are also two gaskets....a cork gasket and another made of a grey fibrous material (similar to most ive run across). Which one goes btw tranny and retainer and which one goes between retainer and the cover housing?
I assume RTV is in order...I love slopping it over everything...
Additionally, Im looking for some better instructions on taking apart the console and how "exactly" to fill it up with the recommended 6 qts of Amsoil.
Thanks in advance...
Stew
__________________
2001.5 Sport SLT Plus, 2500 QC/SB 4x4, H.O. CTD, 6spd NV5600, 3.55 Dana 60/80, Black/Grey. 285/75/16Michelins, AFE Stage II Pro-Dry, Fleetguard filters & AMSoil in almost every hole.
Only 93K.
2008 Yamaha R1.....mods
2004 CRF450.....mods
SOLD - 2005 Silverado, 2500 CC/SB 4x4, D/A, 9in. Cognito, Dual Fox 2.0s, Deaver packs, 37in. Toyo MTs, 18in. MKW MK19, AMP Research steps.
Rangers Lead The Way!
24Vsporty is offline   Reply With Quote
Old 11-19-2009, 07:38 PM   #2
Clunk
Clunk's Avatar
I'm happy with Amsoil lube in my 6spd. for 2 years now.
They're not clear with their instructions because they don't know which direction the PTO gear turns as you go down the road.
I don't know either but with the scoop turned up, it's gotta catch and filter some oil every now and then...shifting gears or just sloshing around.
Your guess is as good as mine on the gaskets.
I filled mine with a plastic gear oil hand pump available at the auto parts store.
I squirted it through the top PTO cover bolt hole so I didn't have to take the console loose.
__________________
'01 2500 4x4 Red QC Sport HO SWB, 6spd.,cowl hood, 4" ex., BD Comp wire tapped, Banks boost & pyro pillar mount, single Carter 4601hp lift pump next to the fuel tank Sept. '04, US Gage & 5 grease gun lines for fuel pressure monitor, Power Service in the tank, Amsoil in the trans and Valvoline in the pan, Vulcan Big Line kit, 8psi WOT on 3X5, BHAF, cheapo fuel cooler, big hole injector nozzles, Cat C300G 62-65-.70a/r
What's yer lift pump fuel pressure?
Clunk is offline   Reply With Quote
Old 11-20-2009, 09:14 AM   #3
ted_pulliam
wow, I had exactly the same question, but figured it would be hard to find someone with that much knowledge of the NV5600, and so I angrily installed the filter while muttering "things".
The instructions mentioned other types of transmissions but said nothing about the NV5600, and they didn't give you a picture of what gasket goes where.
Anyway, it would be nice to know how to use the filter to its greatest effect, but until then, I've got mine installed on the driver's side, with the TOP side installed upwards. I hope it's doing something, but I am not sure.
Ted
__________________
2001.5 2500 QC H.O. 6spd. 4x4 , 2" Rough Country leveling kit, spray-in bedliner, Westach FP Gauge, pillar mounted 3 gauge pod, 305/70-16 Wild Spirit ATs on Pro-Comp 1069s, Bushwhacker Extend-a-Fender flares
ted_pulliam is offline   Reply With Quote
Old 11-20-2009, 09:20 AM   #4
nkennedy
The shift tower comes off easy. Undo the four bolts holding it down, and lift it up. You have to take off the cup holder first. Remove the boot too. It didn't take me over 1/2 hour the first time I did it to find all the screws.
__________________
01' 2500 CTD w/ 6 speed, Edge EZ, Boost Elbow, Gauges & Jacobs Exhaust Brake
nkennedy is offline   Reply With Quote
Old 11-20-2009, 09:40 AM   #5
SIXSLUG
SIXSLUG's Avatar
I'm not sure how effective a filter would be on the 6-speed if it is just relying on slosh to supply the filter and no pick up in the lower portion of the case and no pressure to force the fluid thru the thing.
I would assume the cork gasket goes to the removable portion to r/r the filter element and the paper filter would go between the case and filter housing as a permanent seal.
Be sure to pull the cup holder tray on the console and get the screw under it. The shift boots just pop straight up and expose the other screws. When removing the four bolts holding the shifter in place gently lift straight up and make sure the black plastic bushing on the end of the shifter shaft comes out and doesn't fall into the trans! You may want to get this going first before you replace the PTO covers if you pulled them to drain and wipe out the case.
Unless you really lunch the trans most of the stuff in there is yellow metal from the blocking rings and fine fine metal dust that collects on the bottom of the case. I'm not convinced this filter is really effective or needed. Just my .02
Kurt
__________________
Kurt
2001.5 2500 QC LB 4WD H.O. 6-SPD SLT Laramie Plus
Arctic White,3.54's, Camper/Tow, Stull SS Running Boards, A.R.E. Cab-Hi Canopy w/ SS Vanguard rack, Southbend clutch and hyd.,Power Service, BHAF/Heatshield, MBRP 4" TBE, FP Gauge, Femco E-Z Drainplug,DSS, Thuren Trac Bar, 2" leveling kit, P/H Tow Mirrors, new intank LP @80K, 95K miles.
Good judgment comes from experience, which often comes from bad judgment: W. Rogers
Support Our Troops! NRA, MSBL, BYO, GSP
SIXSLUG is offline   Reply With Quote
Old 11-21-2009, 04:54 PM   #6
24Vsporty
24Vsporty's Avatar
Thanks for the responses. Makes sense about the gasket...good tip with the shifter as well...but, now Im wondering if I should even install this thing at all.
How many of you rowers out there are actually using this filter?
Did the front diff today and will change tranny fluid tomorrow... quick feedback appreciated.
Stew
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
