Thread Tools | Search this Thread | Display Modes |
#1 | ||
nv5600 6spd hard to get in gear now
#2 |
I would say your clutch isn't completely disengaging if it shifts fine when not running. Might want to try pushing the clutch pedal all the way to the floor with every shift if you're not already doing that.
Waylan
__________________
'98 2500 QC 4x4 12v, 3.54, 5-sp., DSS and 03 track bar upgrade, Ranchhand FRB, KDP killed, KORE Pace, Scotty II, Valair 13" conofe, #100, 4kgsk, 16*, HTB2 62/12, MBRP 4", hvy dty valve springs, head studs, frybrid conversion kit. |
#3 |
once its in gear and im moving it shifts just fine, its just trying to get into 2nd or reverse from a stop
#4 |
Move it into 3rd first then try whatever gear.
#5 |
Does double clutching help?
__________________
2000 Quad Cab 3500 4x4 SLT+ Sport, 6 speed, Permatech Bedliner, Rickson 19.5 Wheels w/ 245/70 Kuhmo KRD02, Denver Off-Road Front and Rear Bumpers, Edge Comp, DD2's, Scotty Ram Air II Air Intake System, Banks Brake, Banks SS 4" Exhaust, 90 Gallon Combo Toolbox, Isspro EV guages, Front and Rear Mag Hytec Differential Covers, CIPA Towing Mirrors, BD Short Shift 2007 Mega Cab 2500 4x4 Laramie 6 Speed Auto |
#6 |
does anyone read the question????
it shifts like a champ once im moving, i can double clutch, normal shift, or shift at the right rpm with out the clutch if i wanted to...doesnt matter its perfect once moving im talking about when i stop, and the truck is in neutral, when i try to put it in gear again to take off(and thats any gear, reverse and 2nd i use most but to check i tried putting it in any gear from a stop and it just doesnt wanna go without alot of force and that scares me because it feels like im gonna bend/break something using so much force)...its VERY difficult and before the new clutch it was not hard at all |
#7 |
Either the clutch isn't completely disengaging or the pilot bearing/input shaft snout is damaged and failing (it can happen when the transmission is reinstalled).
Rusty
__________________
2002 3500 6x4 SLT+ Sport QC, Bright White/Tan Leather, ETH/DEE, 4.10LS, Westach, EZ, DD2's, SBC Con OFE, Jardine, BHAF w TAG, B&W, Jacobs, Jordan, RS9000's, PowerVision, Line-X, WeatherGuard, etc., etc. 347 RWHP/762 lb-ft (Dynojet 3/13/04 - uncorrected) 2004 Doubletree Mobile Suites 36RE3 5ver 2007 BMW K1200GT BMWMOA 120519 |
#8 |
any way to figure it out without pulling the tranny...would someone at a tranny shop be able to tell me if they felt it, saw what im talking about? or is it one of those things where i absolutely have to pull the tranny and do a visual inspection
#9 |
Have you tried double clutching like soneone else said earler at a stop. Are you pushing the clutch pedal all the way to the floor and you don't have a floor mat under the clutch at a stop. Like you said it shifts fine when moving and fine when stopped with the engine off but no at a stop when the engine is running. That would tell me that your trany is just fine and you clutch is not disangaging enough to let you put it in gear at a stop. It is pobably not disangaging all the way when moving but like you said if you shift at the right time you don't need a clutch when on the move so you may not notice a problem. The only realy important time the clutch has to totaly disangage is at a stop. Check you clutch
__________________
2002 Dodge Ram 2500 SLT+sport short box quad cab HO 6spd 4x4 410 gears black with stainless trim Gauges BHAF silencer ring MIA Wildernest canopy and a Smarty 1952 Dodge M37 weapons carrier (Canadian model) 1979 Chevy Monza spider 350 4spd 1924 Ford Model T bone stock and yes it is black Without a spell checker I'm lost so be warned |
#10 |
I had the same problem after installing my new LUK clutch and all new Mopar hydraulics. I pulled my slave cylinder and manually compressed the piston holding the slave in an orientation that any air in the system would be forced up. Make sure you compress the cylinder slowly. After I did that getting into gear when stopped was much easier, not as easy as it was before replacing everything but liveable. That's really the only thing you can try without pulling the tranny since there is no inspection cover on the bellhousing.
__________________
2000 2500, 2wd, SO, NV 5600 6-speed, 3.73's, quad cab. Stock except for guages, Carolina Clutch dual-friciton clutch, and Vulcan big line kit. |
#11 |
we had a nv 4500 that did that exact thing... we took it to the dealer .. the tech put in half a bottle of friction modifier for limited slip rearends... sifts like a champ now. not sure if it works on a 5600 though....
justin
__________________
98 12v QC 4X4 AUTO. 4" exhuast. SAII. HTB2. 3pc manifold. 3k springs. tripledisk converter. BrownsDiesel Custom valvebody. 370s . Thanks To :: ********** ********* ********* ********* |
#12 |
Location: Used to be missoula, montana: Now in Sonoma County California
Had that happen with mine, the flywheel when it was machined was a little too deep, thus the factory bolts were bottoming out before the pressure plate was flush with the flywheel. pm me if you are interested otherwise i wrote a thread about it back in july
__________________
03 CC LB 3500 4x4 Atlantic Blue 6spd 305/555 ..... .HE351 bored WG smarty 4.11. 180k miles and counting Jeep Cherokee S chief WT 4BTA Cummins Conversion HY35 ....nv4500/D300 3.54's 33's power loks F&R. 4BTA installation thread: ( Link removed signature violation) "May God have mercy on my enemies, because I WON'T!!" -General George Patton |
#13 |
Sounds like you have air in the hyd. system. Sometimes it is difficult to get all of the air out. bleed it some more.
__________________
99 ram 3500 ctd 2wd drw quad cab 5-spd 4.10 silencer ring removed , muffler & tailpipe deleted, RV 275s, edge ez , westin push bar alpine cd player, jbl GTQ 400 amp, Delphi xm radio, MB Quart components, alpine 5.25" components, aux 55 watt backup beams 150,000 mi. on original vp Walbro 392 pump (20-idle 15-cruise 11 wot) regulator not needed, relay not needed |
#14 |
Sounds like air in the system.
__________________
"The Beast" 1978 V-Dub MK1 Wabbit Diesel, 4spd, Pump Tweaked, 87k Original Miles ***R.I.P 2002 CTD 4x4 Hand-shaker 374hp/915tq*** U.S. Navy Seabee Veteran We Build, We Fight, We Drink More Beer! |
#15 |
That is the same answer everyone gave me i replaced the master slave assembly twice. peter from SBC informed me that it is becoming a common occurance that when these flywheels are resurfaced the stock bolts bottom out so washers and/or lock nuts are needed to take up the slack. The 98-2002 hydraulic clutch assemblies are pre bled you should not have air in them. i thought and attempted the same thing Peter told me it was pointless if the setup didnt work fromt eh get go something was wrong that was not going to straighten itself out we swapped out several assemblies before determining that i amd one of the many who are finding that the flywheel bolts just barely bottomed out enough to make the pressure plate look like it was totally seated but had just a hair between the flywheel and pressure plate allowing the pplate to travel a little before disengaging the clutch thus not fulling disengaging the pplate from the disk and giving you the pedal down creep. if you had air in the system it would probably bleed off while you have the pedal towards the floor thuse sitting on the floor it would not only creep but mostlikely re-engage the disk as you lost pressure.
my thoughts and experience but im thinking you may have to pull this apart and see if there is just a hair of a gap between that pressure plate and flywheel. i say this because it did it with your old hydraulic clutch assembly and with a new one. something tells me that two bad assemblies back to back is not common, especially when dealling with pre-bled sealed systems, when one worked just fine before the clutch job and didnt after, how does air get into a sealed system unless there was a scar or gouge in the cylinder, if this was a 94-97 truck i might wager this but a 98-2002 if it wasnt bleeding off pressure and then engaging uncontrollably i seriously doubt air got into that prebled system. that said this may be internal issue like mine was, as simple as bad luck that the bolts bottomed out in thier holes just a thread too soon. Im emphising this because i have run into this on numerous truck since doing my clutch job where many guys said oh its the slave assembly and spent alot of time chasing the wrong issue and then finally had to pull it back apart. ' FYI you are describing partial disengagement. only a few thing cause this on a diaphram hdralic assembly like dodges use. |
| Display Modes | |
