NV4500 swap
NV4500 swap
I am in the process of getting ready to do a NV4500 swap from the Gatrag 360 in my W250 and trying to find parts to do it. I found this web site that has the adapter kit and a tranny.
http://www.smartpartsauto.com/manual...500_dodge.html
What I am wondering is if any one has done any business with them. Are they good to work with. I really like there price on the tranny.
Last edited by Zeb Christensen; 10-23-2014 at 08:51 AM. Reason: web site was wrong
I guess I should have posted this link too.
http://www.smartpartsauto.com/conver...0_712584a.html
This is the adapter kit so that I can use the stock adpter plate and starter and what not. I am still wondering if any one has done any business with this company.
My dad has one of those bellhousings. It looks better than the Getrag one it replaced
I recently did the same swap with the AA kit. the biggest problem I had was that the barring tool pocket in the AA bellhousing was not cut right and the barring tool could be inserted but not removed. I spent an hour with an end mill chucked into a drill hogging out aluminum, bolting it back up, testing the barring tool fit, doing it all over again. I would've been really PO'ed if I had bolted the trans up before I discovered the problem.
The only other issue is that the cross member adapter is really thin and chintzy. I used 3" x .25" sidewall square tube.
I bought the AA kit, NOS trans with updated mainshaft, shifter stick, shift tower, and 2.5 gallons of the recommended lube from Midwest Trans for $2500 shipped to southern PA. They were really good to deal with.
http://www.midwesttrans.com/NV4500/new_nv4500.html
I have done four NV4500 swaps. Two getrags and two auto's. The AA kits were used every time and with great success. Only one did I have to do any machine work on the input shaft as it wasn't splined back far enough. It wasn't a big deal anyways as the retainer has to be removed to be shortened anyways. I always had a machine shot put it on a lathe to cut it perfectly true. Anyways, if the AA kit is used nothing from a 2nd gen is needed. The only thing about the AA kit is the very weak 4x4 shifter rod. I have had two AA rods bend and not allow the 4x4 to engage. I had my brother who has machine work capabilities at work to make me rods that mirror the thickness of an OEM rod but threaded like the AA rod. Worked out perfectly.
As for price three times I have bought a used bell and just ordered the gated shifter bracket and cross member bracket from AA. Its so simple and easy to go that route. Or at least it was for me as it seems more familiar than installing a Getrag.
The problem around my neck o' Pennsyltucky is that 2nd gen 5 speed trucks in bad shape are still going for $4500. There is a local guy that buys them up and parts them out. He wants (and is getting) $3500 for the "complete" auto to manual swap. For a 1st gen owner this means that you end paying $3500 for a bunch of stuff you can't use and a transmission of unknown history and mileage.
Diesel-Dan
0
07-26-2004 03:27 PM
