Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 02-15-2006, 06:21 PM   #1
horton
normal oil pressure
my oil pressure gauge stays at about 60psi when the truck is running even at
idle. Is this normal my cousins truck runs at about 35-40psi at idle and climbs to 55psi while cruising but her truck is an S.O.
__________________
My trucks: 2001 2500 H.O. 6spd. 4x4 quad cab lwb Autometer FP, boost and pyro gages, Walbro fuel pump kit,AFE Stage II, straight pipe. 2004 2500 305/555 auto 4x4 quad cab swb, stock.
My Dads truck: 2006 2500 325/610 auto 4x4
quad cab swb. Muffler Deleted.
horton is offline   Reply With Quote
Old 02-15-2006, 06:45 PM   #2
mini14
mini14's Avatar
if u had the reflash at the dealer this is normal.
__________________
99 auto 4x4 4.10 rear,no s ring,bhaf, edge ez, 4" s.s. magnaflow
05 Q.C. auto, stock....for now...
mini14 is offline   Reply With Quote
Old 02-15-2006, 07:04 PM   #3
JARHEAD
JARHEAD's Avatar
What reflash at the dealer?? Mine runs at above 40 cruising and drops to around 25-30 while at hot idle. What will that reflash do?
Kip
__________________
2007 2500 Quad Cab, Laramie, 4x4, short bed, stock
JARHEAD is offline   Reply With Quote
Old 02-15-2006, 09:15 PM   #4
I PASS GAS
I PASS GAS's Avatar
It basically turns your perfectly functional oil press. gauge into a dummy light. In other works, when the oil pressure fluctuates (reving up, settling back down to idle, etc.) the gauge will read the same pressure no matter what. Only when the pressure drops down to nothing will the gauge (along with the dummy light) that there is a pressure problem.
__________________
2001 2500 SLT Laramie CTD, QudadCab, Long Bed, Auto, 2wd, 3.55 125,000 miles
Mods to date: Silencer Ring MIA, BHAF, Rip Rook's Dual 4" Exhaust System, Rancho 9000's, OEM Fog Lights, Aux Reverse Lights, Chrome Westin Nerf Bars, Kickin' sound system
I pass gas--Cummins Turbo Diesel!
I PASS GAS is offline   Reply With Quote
Old 02-15-2006, 09:32 PM   #5
horton
i'm not sure if it has been reflashed i bought the truck used. why exactly do they reflash it?
Old 02-15-2006, 09:47 PM   #6
bwarren86
bwarren86's Avatar
at idle with engine hot it runs on the low side but off idle it climbs to about 55
__________________
2009 dodge 1 ton 4 door auto
Line-X liner
B&W Gooseneck
ranch truck 2004.5 3/4 ton reg cab sl ctd 4x4 auto trans with a cannonball bale bed
bwarren86 is offline   Reply With Quote
Old 02-16-2006, 03:40 PM   #7
mini14
mini14's Avatar
reason for reflash is dealer likes an easy fix for easy $$$$. if u live in cold climate this is normal, pressure can go as high as 100psi in cold. thats the reason for a heavy duty oil filter like the fleetgaurd.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
