Noise in the front -- can a failing fan clutch squeak?
Compressor squeeks usually occur when not turning, and are in the idling bearing in the pulley assembly. When the clutch is engaged, that bearing is bypassed (locked up so to speak) and the only noise would be from the compressor itself. It would be unusual for it to do that very long without total failure.
Before you get all carried away, the AC compressor puts a big load on the belt, and if it's prone to, that's when it'll squeak. Try a new belt before you spend a lot of time and money on it. Also look at both the crankshaft pulley and the AC pulley for signs of wear as I stated previously.
The pulleys appear to be in good shape. My previous belt had no markings or label on it whatsoever, and I'm guessing it was very cheap quality-wise. It wasn't terribly old and was installed by Cummins Power South , so I never suspected it as the culprit.
My new belt is one of the solid green ("premium") Gates belts that ran me about $50, which is still a whole lot less than a new A/C compressor.
Thanks again.
