Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 10-18-2006, 04:19 PM   #1
johnny5.9
johnny5.9's Avatar
No radio, dome light or dash light.
I parked my truck on friday, no problem. I started it up on monday and the radio is dead and dome light and the little light that lights up center of dash. The backlight on the guages still works fortunately. I checked the fuses and it's still intact. Any help out there? I am retaded with wiring.
johnny5.9 is offline   Reply With Quote
Old 10-18-2006, 04:37 PM   #2
wannadiesel
What year?
It really sounds like a fuse, there's not much dead.
__________________
Faith
'93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner.
390 HP/800 TQ on #2 only, 413 HP/852 TQ w/ water/meth - needs more air!
Dead KDP's = 72
wannadiesel@dieseltruckresource.com
wannadiesel is offline   Reply With Quote
Old 10-18-2006, 04:56 PM   #3
johnny5.9
johnny5.9's Avatar
It's a 91.5. I checked the fuses they're fine maybe I should change them anyway.
Old 10-18-2006, 08:17 PM   #4
KB440
KB440's Avatar
Sounds like a fusible link, this has happened to my 92'
__________________
Kevin
1997 Dodge Ram 2500 12v...all stock for now
1997 Dodge Ram 4x4, 406ci, D60/70 4.88, 38.5 Boggers, 12k MM winch and custom bumpers.
KB440 is offline   Reply With Quote
Old 10-18-2006, 08:23 PM   #5
rlyons
rlyons's Avatar
Check the fuses with a voltmeter or test ligh or just put in new ones, they are cheap. These fuses will fool you some times.
__________________
92 D250 Club Cab 4X2, 5 speed, ASA Modifieds Intake, Jannetty Racing Team Exaust System, Tweaked Pump, 3200 RPM Governor Spring, M&H M3 Fuel Pin and Timing Spacer, HTT Stage III Turbo w/16cm2 , Pyro/Boost/Tach Guages, Power Wagon Injectors, KDP Tabbed, Borgeson Steering Shaft.
rlyons is offline   Reply With Quote
Old 10-18-2006, 11:00 PM   #6
Micaiahfied
Micaiahfied's Avatar
it's not a fusible link (guess it could be) but this just happened on my 92 not to long ago, couldn't figure it out at first... i believe it's slot #12 on the fuse box it's the "int lts/dome" fuse. it's up next to the 3-5 amp fuse, top of the block on the right, for some reason if you pull that fuse it kills the radio as well. mines got a 10amp in it... not sure it that's the right one or what i had laying around hope this helps! (don't mess with those fusible links unless you absolutely HAVE to! )
__________________
1991 W350 SRW, 36" cab stretch, NV4500. 4.10 lsd. 61k. 2nd gen. seats, gauges. pump tweaks. PODs. TIMING. 12cmWG. HTT Stage III. Water Methonol. BHAF. #2 311.5hp 723.8tq WM 372.5hp 837.1tq
Past trucks: 1992 D250 CC Auto, 1992 W250 CC 5spd, 1991 W250 Auto, 1993 W250 NV4500, 1993 W250 auto, 1991.5 W250 auto, 1992 D350 auto dually, 1992 D250 CC Auto, 1985 D350 4-door auto dually (gasser)...
Micaiahfied is offline   Reply With Quote
Old 10-19-2006, 09:48 AM   #7
johnny5.9
johnny5.9's Avatar
Thanks for all your help guys. I am going to check that fuse for the dome light, I think I might have missed that one. I agree about not messing with the fusible links unless absolutely necessary, I had to do it once before, what a pain.
Old 10-19-2006, 10:18 AM   #8
johnny5.9
johnny5.9's Avatar
I told you guys I was a wiring retard. I checked the dome light fuse at the top of the block and it was smoked. I guess I just never noticed it up at the top before. I checked the radio fuse and after finding it was good I just assumed that it must be a wiring problem. We all know what happens when we assume. Thanks alot.
Old 10-19-2006, 10:37 AM   #9
Micaiahfied
only reason i knew to point you in the correct direction is that i spent an hour or 2 trying not ot fix it the easy way lol. i never seem to look for the obvious... johnny, when you eventually do you front brakes let me save you some trouble.... you DON'T have to disconnect the brake line to change the pads i wasn't the only one to think that (thankfully) but man i felt stupid when i saw how hard i was making it on myself!
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
