Sign in using an external account
Thread Tools | Search this Thread | Display Modes |
#16 | ||
#17 |
maybe check the wires in between the door and jamb, they crack and break from the door opening and closing
2011.5 Ram 2500 Crew/SB Laramie 4x4 800lbs HO 1982 Dodge W350 Crew cab Cummins with 5spd 94 2500 4x4,93 W350 Dually, 92 W250, 1950 powerwagon 6bt/5spd My build thread; http://www.dieseltruckresource.com/d...d-t288785.html |
#18 |
any ideas on which wire
#19 |
I cant recall off the top of my head but I'm sure someone with a FSM will answer soon. Shouldn't matter though, once you cut the pack of wires open its pretty easy to see which ones need help
#20 |
The power window wiring is mostly 14g, with 1 or 2 12g wires, usually 19 strand. They fatigue and break inside the loom that goes through the door hinge area. When they do, they usually just open up, but the broken wires also can work their way through the insulation and short to adjacent broken wires.
If I tackle one, I replace the 19 strand wires with much finer stranding, at least 41 strand, and finer if I can find it. Usually such wire will be marine or aviation stuff and tinned to boot, so when I install it this time, it will be the last time. The job is an all day sucker. Might as well replace the lock and speaker wiring at the same time. |
#21 |
IGNITION SWITCH! mine does the same thing. try wiggling it around and turning at the same time. i can always get it to work.
91 dodge w-350 SRW non IC 93 w-250 ext. cab IC |
#22 |
That's exactly what was wrong with mine when the fan motor and electric windows quit. Both run off the same terminal, new switch cured it.
Bill |
