Thread Tools | Search this Thread | Display Modes |
#1 | ||
new tires- what do ya think
__________________
79 F250- 93 5.9, p/s i/c. he351cw turbo, 3rd gen intake, 3200 spring, Denny t fuel pin, ddp stage lll injectors, piston lift pump, pump is turned up, kdp kiled, custom made 4" down pipe, 5" stacks. A518 auto, sun coast converter 1 ton axles 3:54 gears. Autometer gauges |
#2 |
Very nice!!!
__________________
2007.5, 2500HD, QC, Laramie, 4X4, SB, 68RFE, 3.73, Inferno red, Edge Insight w/pyro, MaxBrake, DSS, Firestone Ride-Rites and controller, Air-Zenith air compressor, Bilstein 5100's, EZ Change Drain plug, 250 watt oil pan heater. Toys... 2010 KTM RC8, Annitori Quickshifter, (Orange, the fastest colour) 2008 YZ450F stock 2006 SX Viper Mountain, Boss Seat, Bender can |
#3 |
looks great!! nice lookin truck
#4 |
I'm still on the fence about which direction these tires look better... You and I have them the same way with the "V" in the middle looking like it is directional. But the side lugs all look like they're going backwards... Now picture the four rows of lugs and group them two by two and look at the direction... I know the middle looks like it would be going backwards but this way there are two sets of forward looking lugs!
__________________
2012 3500 CCLB SRW G56 4x4 1973 Ford Courier Crawler |
#5 |
I like them that way!
__________________
1993 250 single cab 4x4, "Big Red", Phatshaft 62 Turbo, 4" exaust, NV4500, Southbend 13'' clutch, Industrial Injection performance pump, 5x.014 sticks, Raptor 100 fuel pump w/ Donaldson prefilter, 4" skyjacker and 37" Goodyear Wranglers on 16.5 old school chrome wheels. 361hp and 787 ft lbs on 4/13/2013 1991 Toyota P/U w/ 4bt, th350, coil spring dana 70 rear and 60 front (welded) w/ 5.87 gears and 44x19.5 Boggers. |
#6 | |
Quote:
#7 |
I like the black letters out for sure and the way they are in the first picture....
Beautiful truck.
__________________
91.5 W250 4x4 5 speed LE Red/Grey, 270k miles, 3.54's w/ Power-Lok, 4" Exhaust, BHAF, DennyT Pin, 3200 Spring, Piston LP, Power screw maxed, HX35/12cm, DAP 5x14 Injectors, Valair 13" 550hp K/C clutch, 4" Skyjacker soft-ride lift, 315/75R16 Mickey Thompson Baja ATZ tires, 16-17 MPG 89 D150 3.9L TBI/A999 Auto, beater while ^^^ gets restored Attending LTI for Diesel Truck Technology, graduate December 2013 |
#8 |
very pitty very pitty i like
__________________
1990 W250 bought new in Nov. 89 performance built 727 and torque converter , high miler 800 k kelderman air ride 2001 2500 HO 6spd 4x4, Engine brake ,fass,SBC 4" turbo back exhaust BHAF fluid damper,ARP head studs, DSS, Fast cools. wife says trucks fast enough:( How many of your rights are you willing to give up before you feel totally safe ?Wake Up People vote EVERYONE OF THE BUMS OUT OF OFFICE! |
#9 |
looks good!
__________________
Josh PADTR#15 Member Current: 08 Silverado 1500, 5.3, 4x4 few goodies Still looking for a Cummins... Fast, Cheap, Reliable... Pick Any Two |
#10 | |
Quote:
http://www.100dollarman.com/tires.html |
#11 |
i have the 36's but when these wear out i think im going to switch to those. just want to lift my truck a little more to fit them better.
__________________
Henry 91.5 W350 92 d250 |
#12 |
That truck is friggin beautiful. Love that bodystyle!
#13 |
how much lift do you have now with the 36"s???
__________________
1990 w250,5spd,american racing wheels wrapped with mud claws,automeater c2 boost and pyro,BHAF,interchiller,2nd gen intake manifold,HTT 64/71/14,dennyt and minor pump adjustments. |
#14 |
I love that truck man!!! I love that style of fords! I'm gonna make a fummins like that someday. NICE WORK!!!
__________________
Black 92 W250, LE, 3.54s, Outlaw Diesel built 47rh, 14mm VE feeding 6x18s (both built by me), 4200 gs, Bullseye 66/71/14,6" hood stack,ARP Head studs, 60 lb valve springs,PS intercooler,timing jumped a tooth,Airdog II 200gph, 1/2" lines, Custom ACE fuel sump and grid delete 375hp 769 ft lbs with stock a518 trans, 5x13? injectors, and aurora 5000 8/20/11 450hp 1008ft lbs after 47rh swap with HE351CW and PODs 6/9/12 |
#15 |
i just have a add/leaf in the front. these tires rub if i go into a parking lot at too much of an angle
| Display Modes | |
