Thread Tools | Search this Thread | Display Modes |
#1 | ||
__________________
NOW: 2008 Dodge Ram HEMI...1500 BIG HORN White 4X4. Loaded! ARE Z-Series Topper, 2" HBS Leveling Kit, 17" Mickey Thompson Classic II's, Bushwacker Pocket Flares.... 2006 G56 Traded 2006 48re Broke/Traded 2003 S.O. SOLD... 2001 H.O. SOLD... :( |
#2 |
I got one on the way. I'll be using it with the Commander I got.
I'm not a huge fan of moding up a new under warranty truck but I just had to give this a try at $269.00 bucks. I'll be pulling a 12,000lb 5th wheel next year and I want a little more umffff on the hills. I'm not looking to tear the truck apart and play games with my warranty, I hope this thing is what it looks to be. I'll be interested in your findings.
__________________
06' 3500 MegaCab SRW 4x4 STL MegaCab Club Member #74 |
#3 |
I can already tell you that the ummph that you are wanting while pulling that 12000 pounds will be there with the XZT!! The Chip is so smooth compared to stock!! It makes driving the truck allot easier. I know that there is more power on tap and that the fuel mileage should go up because there is less throttle input to make this beast go. What Tranny do you have??? I have the G56 Manual and the engine seems to hold the revs a little longer than stock and that helps in the shifting department. I have pulled 16000 with this Truck so far while stock and was impressed. I cant wait to do that with the XZT-----I'll bet 5th Gear will not be needed where I go! I'll post the results probably Thursday or Friday of this week. Got to burn a whole tank of Fuel before I can post the results. JB
#4 |
JB, I have auto tranny 48r 4.10s
#5 |
I have owned 2 Auto Tranny Trucks but have never had a XZT installed on one. I did however have an 03 that had the 4.10 Gear's and that was a pulling machine even with the 47re--
! I hated that Tranny!-----Anyway, you will definatly be able to feel the difference. Not incredible power increase, but a definate increase. ----- How's the weather in Cali??????? It's rainy and COOOoooold here in NC!
#6 |
Oh and I wouldnt worry about the 12000 pounds and the 48re-------it is capable of handling more than that---Trust me, been there and done that!----Dads Dually with about 26,000 behind pulling 3-5% Grades! Tranny would get warm, slow down, cool off, get going again!
#7 |
Rite on.....the weather is real nice, a tad chilly for Ca. as in 50's . But nice.
I look forward to your report. Have a good Christmas |
#8 |
Ditto-----------------------------------------!!
#9 | |
Quote:
__________________
'05 CTD, QC, Laramie, 4WD, Auto, XZT+, ARE CH cap, LineX'd bed, updated steering, Corsa exhaust. '87 Cherokee, Laredo, 4WD, 5-speed, Borla header, Indexed distributor, K&N air filter, MAP adjuster module, Front/engine/transmission/transfer-case/fuel-tank skid plates, Rocker sliders, Dana 44 rear axle, 4.88s w/ front Detroit locker, 6 inch lift, 34x9.50-15 TSLs, ZJ steering. |
#10 |
2005 dodge 2500 4wd slt, quad cab short box with brute force intake, and straight pipe at 1500miles
before quad....17.8mpg after installing quad at 4000 miles......16.3mpg I drive very conservitive. I don't go over 60mph ever. I am a little dissappointed in the box. I will however keep it till I get 12,000 miles on the truck, then will see what it can do. I expected with my combo to get atleast 20mpg.
__________________
2005 DODGE CUMMINS SLT 4WD QUADCAB |
#11 |
--- That dosen't sound good at all!!!! A decrease in MPG while driving conservative is BAD!!! Oh-well, I will know in a couple of days! I have 8256 on the Truck right now!
#12 |
I didn't notice a huge increase in power when I installed mine either...'Till I took it back off to get a reflash!As for pulling power,you will definarly notice when you're pulling.I can now leave it in O/D on 6% grades.EGT's are @1250 now,in O/D on those grades.Before I had to downshift to 3rd,& was @ 1400EGT.What a difference.Go Quad!
__________________
Patriot Blue 04.5,2500,SLT,QC,4X4,LWB,325/600 CTD,BILLET GOEREND & TRIPPLE DISC,SRW,3.73 LSD, SMARTY TNT,X-MONITOR & Isspro Pyro's Pre/Post Turbo,AUTOMETER FUEL PRESSURE,DiPricol RP,5" TBE,AFE Stage II PG7, HTT62/13ss/65,SNOW st 2,CARTER P4601HP LIFT PUMP, 2" LEVELING KIT,HELWIG SWAY BAR, 285/70R17 TOYO A/T's, Chrome Nurf Bars,Bushwhacker Flares,BUCKSTOP OUTBACK BUMPER,FIRESTONE RIDE-RITE SPRINGS, 9' OKANAGAN CAMPER 430hp/803tq 2/16/08 on 4.11(TNT now) HP?/TQ? SAC # 172 |
#13 |
pulling 8%
when I leave town for warmer climes this week, I will have to pull an 8% hill that is over a mile long and twists and turn. it even starts with a turn so you can't get a high speed run at it. This is the worst hill on our route, although climbing out of SLC to Evanston is a serious pull, and a long one. Mostly 6% I think. The trailer is about 7,000 lbs, plus the ATV is in the truck bed. We're pretty loaded up, but not carrying water, since it is pretty cold.
I expect to have no trouble unless the roads are slick.
__________________
www.tigerforcerecon.com 2006 2500 4X4, QC, long bed, Auto trany, Diesel, pretty much stock. Xzilaraider Chip and Quadzilla Commander. Running boards, Grille Guard, and 100 Watt off-road lights. Timbren Overloads, front and rear. Towing a 29 ft Avion. |
#14 |
Hankpac, You have pretty much the same rig as mine, except for mine being a 3500. I pull a 25' long toyhauler thats 7500lbs +. total Trk & TH full of fuel and goodies is 15,400 without me or the wife. Pulling the Grape Vine Pass (5 Frwy) in central Ca. is a piece of cake with my truck full stock. I can pass any thing with power to spare.
With the XZT on your / our truck(s) we should be able to fly up 6% with a 7000lbs trailer
#15 |
Bump for the Results that will be here probably at the first of next week!! Sorry for the wait guys! I just want to run the entire tank empty to get a longer/more accurate reading!!
| Display Modes | |
