Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Generation Ram - Non Drivetrain - All Years
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 05-31-2012, 09:32 PM   #1
joeinblueout4u
joeinblueout4u's Avatar
New to me 2003 2500 Q cab 4X4, have questions
We just got rid of the 2001 Ram 3500 2wd and picked up a 2003 Ram 2500 Quad cab with automatic and 4wd. Today while driving on the turnpike, I noticed a slight vertical "bouncing" in the steering wheel from time to time. It seems like there may be an 1/8th of an inch of vertical play, but no side to side. What do I need to be looking at?
Also, I twice noticed that with the ignition key "off" and out of the ignition, the power windows would still function. It is not doing it now, and I cannot duplicate this. What would be the cause?
The truck is an SLT package with power locks. It did not come with fobs for keyless entry. Is this just something where fobs can be purchased and the truck / fobs can be programmed, or would it need to have come specifically with keyless entry for fobs to be of benefit?
-Joe
__________________
2001.5 Ram 3500 5 speed, Bone stock.
Gravity is a wonderful thing...until it proves you wrong.
joeinblueout4u is offline   Reply With Quote
Old 05-31-2012, 09:50 PM   #2
papaduck
papaduck's Avatar
I can't help with the steering wheel bounce.
The windows can be raised or lowered after the ignition is turned off for a short time if the doors are not opened.
The keyless entry will require more than just the fob if it did not have it factory installed. If you have a key lock on the passenger door it did not come with keyless entry.
__________________
Papaduck
03 Dodge 3500 SLT, HO Cummins, 6 spd, 4x4, SRW, quad cab, short box, gauge on lift pump, oil pressure, boost, rail pressure and EGT, FASS 95 lift pump, Baldwin BF1212 fuel/water sep., Cat 1R0750 fuel filter, steering box stabilizer, 6.7L harmonic balancer
32 ft. 5er Carri-Lite
Previous - 97 Dodge 2500 SLT, Cummins, Auto, 4x4, standard cab
papaduck is offline   Reply With Quote
Old 05-31-2012, 10:03 PM   #3
joeinblueout4u
Thanks papaduck. There is no key lock in the passenger door, so it looks like I will check into some fobs. Did not know that could be done with the windows. The driver's door was open at the time, but I had just turned the truck off and was getting out at the time.
-Joe
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
