Main Page Classifieds Tech Facts Member Photos Articles Links Forums Chat
Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (6.7L Only)
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 06-27-2009, 08:23 PM
TheOutdoorsman TheOutdoorsman is offline
New Here - Gauge Questions
I'm new here, just joined. Just bought a new 2009 3500 with 6.7L CTD. Wondering what gauges and gauge mounts everyone is using. I tow a 15,000 lbs fifth wheel and want to at least look at EGT and Tranny Temp. What is the need for a boost gauge? Can I get a better Engine Temp gauge to replace the one in the dash cluster... it doesn't even start to move until the engine has reached 140 degrees? Any other recommendations?
Old 06-28-2009, 09:37 AM
Jim W's Avatar
Jim W Jim W is offline
Welcome aboard and enjoy your truck. You can do a search on this forum under gages to see what is out there. Their are several different styles for sale some are gages and others are a quad monitor that the user can pick what he wants to monitor.
I have a A-Pillar tri-Gage mount that has Boost, Trans Temp and EGT. The boost is used to monitor the air flow into the engine. I used this mainly when towing, since I am mainly stock. I measure the trans temp at the pan, I run a Mag-Hytec pan which is Al and has extra fluid capacity. The EGT Gage will scare you the first time the truck goes into regen. When you experience the high EGT's that are registered. Just remember that the 6.7L was designed fro these temperatures and you just need to let the engine cool before shutting off.
Keep reading and you will learn from all of the experience of all of the users on this site.
__________________
Jim W. DTR Megacab Club Member #167
08 2500HD Mega Cab, CTD, 68RFE Auto, Mag-Hytec Trans Pan, Front & Rear Diff cover, Smarty, MBRP 5" Exhaust, Silver, Gauges Optix Pyro, Boost, Trans Temp, Westin Side Steps, Bed Cover, Line-X Bed Liner, Prodigy BC, 15 K Reese Hitch and Pulling a 11K 5er.
Old 06-28-2009, 12:44 PM
DarkDesertCTD's Avatar
DarkDesertCTD DarkDesertCTD is offline
Send a message via AIM to DarkDesertCTD
I too am going to go with a 3 gauge A-Pillar mount. They have one that looks factory especially with the Dipricol white face gauges that very closely match the stock gauges. I like the look and location of the A-pillar mounts the best. Only downfall is that you lose your grab handle
__________________
2008 Dodge Ram 2500 QCSB TRX4 4X4 - 6.7 CTD - 6Speed Auto - Factory Exhaust Brake - Mineral Gray
Old 06-28-2009, 04:06 PM
Harvie Harvie is offline
I use the Srt10 pillar mount and a dual SPA guage, keeps grab handle, looks factory and the fastest, most accurate guage made. You could order it as EGT tran temp.
__________________
09 3500 SRW
6.7 6spd SB quad
24K off sticker.....
Richard Head
could not shift std trans.....
CTDs since 94 a million + miles and rolling...
Old 06-28-2009, 11:23 PM
I am interested in a triple pillar mount. Any recommendations where go buy for an 09 Dodge Ram 3500?
Old 06-29-2009, 07:35 AM
Jim W's Avatar
I would check out Geno's Garage. You can contact them at "www.genosgarage.com". They carry the gages, A-pillar and wiring for the install. Or check out this site too.
Good Luck.
__________________
Old 06-29-2009, 06:06 PM
Lil Dog's Avatar
Lil Dog Lil Dog is offline
I personally went with the overhead windshield mount that goes over the rear view mirror. Pyro, boost, Tranny EV2 series gauges. I was going to try the Optix gauges by DI Pricol but they were back ordered indefinitely at GENOs.
__________________
97 2500 4X4 LWB CC SLT Laramie 5spd LSD 3.55.
Isspro EV's pyro/boost, #10 Plate, PEAK 3K GSK, AFC Spring, DDP III injectors, S300 Turbo, PEAK IC Boots, TAG III, South Bend 13-1.25" Con FE clutch, SCOTTY II-UNI, MBRP XP 4", KDP Tab, 16° Timing, SS DSS / 03TBK, Roda Deaco PAS. Espar D5WSC heater. B-Quiet sound deadening inside.
Dyno 09-2009 401 RWHP / 1050 Ft-lbs
'08 2500 4x4 MegaCab Laramie, 6.7, 68RFE, 3.73 LSD, S-67 R15ME.
Alberta Chapter #5 Prez... PM me for details...
Old 06-30-2009, 01:28 AM
mega-engr's Avatar
mega-engr mega-engr is offline
Quote:
Do you have some pics of this mount? How do you like it? Fit? Overall look? How does it mount up there? Any viewing issues? Sorry for all the questions as I'm looking for a good place to mount as well without losing the grab handle on the pillar.
__________________
2007.5 Ram 3500 SLT 6.7L Megacab, 4x4, 6sp. Auto, Electric Blue, Nav & 6 disc changer, Smarty S67 ME14 (SW3), Revertable EGR Plugging and Exhaust Deletes, S&B intake, Amp Research Steps, Prodigy Brake Controller, Wolf Liner O.T.R.
DTR Megacab Club Member #152
Old 11-03-2009, 09:55 PM
Big Oil's Avatar
Big Oil Big Oil is offline
Any pictures of the windshield mount gauges?? Will they work with the overhead display and the oversize uconnect/dimming mirror?
__________________
2009 6.7L Ram 2500, Quad Cab, Long Box, Auto, Laramie... Bone Stock
Old Truck: 1999 Ford F-350 4-Door Long Box 7.3L, BHA Filter, Cirvinie's scoop hood, 5" exhaust, 4" lift, 315/75/16, burned up glow plugs, wont start without plugging in.... worn out POS, traded in with 250,000 miles
Old 11-03-2009, 10:39 PM
Lil Dog's Avatar
The Overhead gauges work fine with overhead display and uconnect mirror. No problems at all. I haven't gotten pics of them yet..Forgot..
__________________
Old 11-05-2009, 12:21 AM
Big Oil's Avatar
post some pics if u can lil dog, i have some phantom II that i took out of my old stroker that i'm thinking of putting in
__________________
Old 11-05-2009, 12:36 AM
bggrndodge's Avatar
bggrndodge bggrndodge is offline
Location: Kodiak, AK (For now but home is Washington State)
I have the A pillar triple pod with the dipricol optix guages. They are as close as you can get to a factory look. The best place I found to get them was from Rip at sourceautomotive.biz. As far as loosing the grab handle, thats why you have a steering wheel!!!!
__________________
2007 2500 Quad Cab w/5.9 Auto,Silencer ring MIA, 2" Hellbent steel leveling kit, 3 guage A pillar w/Di Pricol EGT/Boost/Trans and Smarty Jr
Sold:1993 W250: 8" Nationals up front 5"block & 4.5 springs in rear w/bags,38" Toyo Mud Terrains on American racing Mojave's, 15K lbs Warn, custom bumper, EGT and Boost gauges on pillar, NV4500 5 speed tranny, Borgenson shaft, BAMF CV joints w/ high angle front drive line (42*), Smoke screw & Power screw turned up, 4 inch straight piped, HX-35 turbo
Old 11-05-2009, 01:51 AM
safecracker909's Avatar
safecracker909 safecracker909 is offline
Go with an Edge Insight. It will show up to 4 reading at a time. Also has fun stuff like 0-60 and 1/4 mile tests. It also has the ability to check and clear the CEL. Having the 6.7L also means you will have CELs.
__________________
Neil
2007 Ram 2500HD SLT 4x4, Big Hor, 6.7L, 6 speed auto, K40, Banks Inter-cooler, Banks Ram Air, Edge Juice w/ Attitude HOT Unlocked, Smarty ME Stack. AFE 5" TBE 6" tip. Mag-Hytech Difs and BD trans pans. Amsoil everywhere. 150,000 miles.
Old 11-06-2009, 12:06 AM
Lil Dog's Avatar
Here are some pics of the Overhead windshield pod mounts. I used EV2 gauges from Isspro. This view is as close to where I see them as possible with a camera.
More of a closeup of the actual gauges. Here the truck is running on high idle with the EB on.. Hense the higher EGT and boost.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
