Main Page Classifieds Tech Facts Member Photos Articles Links Forums Chat
Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 12 Valve Engine and Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-02-2009, 08:41 AM
MNorby's Avatar
MNorby MNorby is offline
Send a message via Yahoo to MNorby
Need new thermostat?
In the summer my 97 water temp gauge cycles up and down like normal but in the winter it never even gets to 180. I put a piece of cardboard in front of the radiator with a hole in front of the fan clutch (so it thinks it cold and doesn't engage) and that doesn't help. Heck I even had the cardboard in all last summer and even towing it never gets near hot, just normal cycling from like 200-170 or so like the TSBs explain.
Now that its getting cold out again its never getting up to normal temp and therefore the heater never really works great. Do you think the thermostat is sticking and never fully closes? If so what brand of thermostat is best? Napa, Dealer, etc?
Mods are in my sig and it has 197k.
__________________
1997 Reg cab 2500; 5" lift; 315s on M/T Classic IIs;5" straight exhaust; #100 plate; BHAF; KDP tabbed; Ultra-lite pyro and boost, and other misc goody goodies...
Old 11-02-2009, 08:57 AM
John Faughn's Avatar
John Faughn John Faughn is offline
I went to Cummins , but it seems they sell a cooler temp [ about 165*F ] than what was in it before [ 180* ] .
So I would ask what temps are avalable and get the 180* .
__________________
Build-12-93 Cummins WHC1 94 2500 4x4 SLT AT 3:55 265 R75 16 New Amsoil EAA cone air filter Amsoil 15-40 dualbypass found here about 01-05 DYNO at Mikes feb19 05 245.7HP 597TQ with coming out of lockup -so not sure about HP&TQ DiPrpocl trans temp EGT boost MBRP 4" alum exhaust Centramatics wheel balancers Solid Steel DSS track bar retro fit kit stabbed KDP bio-diesel 25%
Old 11-02-2009, 11:47 AM
infidel infidel is offline
I don't think there is anything you can do about it except use your heater in the recirculate mode.
In the Montana winter I've found you don't even need a radiator, just the heater core is enough to cool the engine especially when sucking outside air.
You can try removing your fan completely, I used to do it back before global warming made our winters warmer but haven't done it for several years.
It does help some. I was able to leave my fan removed from Oct to May with no problems as long as I wasn't towing heavy.
Never found winter fronts or cardboard to help at all.
Changing the stat doesn't help either since very little coolant is flowing though the radiator when it gets real cold.
__________________
Bill
'95 2500 4x4 auto
'95 3500 5 speed flatbed hauler
stock for one day
Old 11-03-2009, 01:44 PM
b4black b4black is offline
My truck wasn't getting warm either. The stock thermostat has a piece of rubber that comes loose and gets caught. It keeps the thermostat from closing completely.
Looked like this:
http://www.mvdirona.com/TechnicalArt...ateFailure.htm
__________________
1996 Dodge Ram 2500 Cummins Turbo Diesel, 12V, auto, 4x4, long bed, long cab
KDP tabbed, 4" exhaust, steering box brace, Luke's link on the track bar,
Old 11-03-2009, 03:17 PM
Diesel Dave2's Avatar
Diesel Dave2 Diesel Dave2 is offline
I agree with Bill...I'm so sorry that I throw my orginal t-stat out...I have tried two different cummins t-stat and same thing....Blocked off the whole rad hasn't helped...I'm going with the fan removal now..Now my truck is under cooling and smokes more because its not up to operating temp....Not good for the motor...
__________________
1995 Dodge,250K miles, regular cab dually,4X4,5 speed,4:10 gears,Wastegate blocked,15 degree timing,Polyurethane control arm bushings,BHAF,KDP Tabbed,Pyro & Boost,DSS,2003 trackbar upgrade,Steerring bushing,#10 plate,3K springs,215 injectors,Laser cut DV,Con OFE,full B100.
Mar 2008,
Dyno: 353HP/735 Ft Lbs
June 2008
Dyno:344HP/835 Ft Lbs
1978 Mercedes 450SL
1956 Chev 4 door Sedan
1977 T/A 400,4-speed
Old 11-04-2009, 12:47 AM
Santaclaus Santaclaus is offline
Take a look at: http://www.dieseltruckresource.com/d...elt+%23k080694
post # 33 & 38 ( in page 3 )
Mike
__________________
92, Extended cab, auto trans, exhaust, boost, tack, oil pressure gauges. Pensacola, Fl.
Old 11-04-2009, 11:18 AM
Mike
That's very inventive, using a shorter belt to bypass the fan pulley.
Never thought of that one.
Easier to remove the fan on a 2nd gen though.
After you've done it a few times it takes less than a couple minutes start to finish.
Nothing needs to be removed except the fan if you do it by pushing back the upper radiator hose, pull the fan up so the oil fill is between two blades then rotate the fan clockwise.
If you're leaving the fan off for a long period store it standing upright.
If you lay it down flat sometimes the oil slowly drips out.
__________________
Bill
'95 2500 4x4 auto
stock for one day
Old 11-04-2009, 01:18 PM
Got my fan off and removed all the cardboard...Running the so called slow opening t-stat from cummins which has a lower operating temp but will elimate temp flucuations.Which it didn't get rid of the flucuations.
__________________
Mar 2008,
June 2008
1978 Mercedes 450SL
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
