#1 |
Need help with turning up a 3116 Cat
Got a 1995 Gmc Top kick with a 3116 5 speed and it is a dog when its got a load.
Anyone ever turn one of these up so it will run like a real truck? Thanks for any help in advance. Rich
__________________
1993 2wd d350, cummins, 12' reading service body 1997 12v longbed xcab 4x4, 4:10 lsd, tow pkg, cd changer, galaxy dx66v, Cooper Discoverer ST 235/85/16 10 ply, Stahl service body, Lund Runner steps,Arrowcraft adapters, Bosch 70hp injectors,TST #10 plate, 3KGSK, Larry B's starter contacts, K&N air filter, Skyjacker 2.5" lift front springs, 9' plow, Air lift Super Duty Airbags, Sirius sattelite radio. 2007 3500 DRW Reg cab, 5.9, G56, 3:73, 4x4, silver. |
#2 |
To gain access to the fuel screw on the 3116, you must remove the valve cover. If the seal tag/plate is still present it will need to be removed. You will need to remove the tag by removing the rocker shaft stand bolt. The screw and lock nut are on the rack bar, and take a 2mm allen wrench and an 8mm deep socket. Turn the screw counter-clockwise to increase rack travel.
Marine injectors are also available for an even better power increase. These engines arent known for making big power, and surviving it. That's from my Low Buck Fuel Rate site. It's no major increase, but it gives it decent pep.
__________________
67 F100, 300, 4V. swapping in a Ford 6.6 from 92 F600. Work truck:94 IH 4900, DTA466(P-pump) 0 plate, 3 clix on gov springs, and timing at 19*, str8 piped, Allison MT653. |
#3 | |
Ad-meany-strator
Quote:
Turned-up medium duty stuff is like a hand grenade with the pin out. You can get away with stuff for years in a pickup that will bite you real fast in a medium duty where the engine is getting worked hard all the time.
__________________
'93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner. 386 HP/774 TQ on #2 only, 408 HP/844 TQ w/ water/meth - needs more air! "Butterscotch" - '82 Mercedes 300TD Dead KDP's = 72 |
#4 |
Thanks, i will try that and try to control myself on the amount of fuel i throw at it. I know these engines are not powerhouses anyways but i just need a little bit more because it won't even pull a hill empty.
#5 |
I would buy a Pyro right away and maybe a boost gauge first to get a baseline and turn the fuel up to point where you feel ok with it. Most of them are not running at full potential, so if your careful I dont see why more fuel would be a death sentence to your little Cat.
DS79
__________________
1992 W350 DRW NV4500 4.10 gears. Fuel screw turned 3 turns, pin turned and washer removed, 16cm housing, boost and pyro gauges Alum. flatbed with hidden goose neck. |
#6 |
no OTR engine is set to 100% duty cycle for longevity.
Say you run at flat out at 60% capacity.......think that'll last longer than running flat out at 100%. most operators care about operating cost per mile. its what makes or breaks you. IMO the 3116s are junk anyways.
__________________
Luke --------------------------------------------------- '97 Chevy V3500 CC DRW 6BT 22" Alcoas '98.5 24v 2500 QC 5spd 4wd Demon hot-rod *sold* '90 VW Jetta 1.6L oilbrnr 5spd coupe wolfsburg '73 RS/Z-28 Survivor. |
#7 |
I would much rather have the C7 over the 3116 any day. Just a much better engine IMO. I agree factory settings are always low when compared to the max performance of the engine. I mean look at what some of the "little" 5.9L Cummins can do!
DS79 |
#8 |
Ad-meany-strator
#9 |
As long as ya dont mess with em. Look at all the switchers that run em. Those things, especially at big warehouses and such, run darn near 24 hours a day, pullin 40,000+ at times.
__________________
02, 24v, 6 speed, Edge Juice w/ Attitude, BHAF, 5" exhaust to dual 7" turnout stacks, 35" Pro Comp Xtreme AT's, silencer ring removed, 1700 watt stereo, XM radio, CB, Eaton Fuller shift knob, Fuel Boss Mechanical Lift Pump, on board plug in jumper cables |
#10 |
But some of those P-pump trucks are running around 400hp at the wheels, which would be well over double the stock HP and they seem to fairly reliable. Besides the 3116 isn't going to run much over 300k miles if it is used hard every day. They just aren't built for it IMO.
DS79 |
#11 |
I got lucky and had one that went over 700k, but it was all stock and never worked hard. If they are worked hard seems many are lucky to see 300k and at well over 10k to rebuild or install a reman I'd play it safe. Next time look for an 8.3 cummins, better performance and longevity.
__________________
#12 | |
Registered user
Quote:
| Thread Tools | |
| Display Modes | |
