Need help
Old May 14, 2013 | 07:56 PM
AWO's Avatar
AWO
Need help
I have 2002 2500 I just had a new injector pump and fuel pump put on.
It starts good when the motor is cold an runs like nothing is wrong with it until I kill and try to start again. It's acting like its not getting any fuel. And had fuel pressure check at idle steady 12-13psi. Any suggestion on what could be the problem would be much appreciated
Old May 14, 2013 | 08:33 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Moved for faster replies
Old May 14, 2013 | 10:30 PM
lovinCTD59's Avatar
Usually a hard start while engine is warm can be a sign of a weak injection pump. Assuming you have no air leaks. Are you getting any codes or check engine light?
Old May 14, 2013 | 10:37 PM
AWO's Avatar
AWO
No codes are coming up and check light is not coming on
Old May 15, 2013 | 08:12 AM
patdaly's Avatar
AWO, when it is warm and you know it will be a hard start, pour a half gallon or so of ice cold water over the VP44 and then see if she starts right up.
All Injector pump rebuilds aren't the same quality, where did you get the pump from?
Old May 16, 2013 | 02:38 AM
AWO's Avatar
AWO
I ordered the pump from thoroughbred.com
smokin24v
Mar 18, 2008 01:21 AM
pwrtripls1
Feb 8, 2008 07:25 PM
spooling
Sep 13, 2007 10:05 PM
coupdetat
Jan 17, 2007 09:23 AM
