#16 |
Not sure? Dont see that on thier form 637(application) or form 720(quaterly return).
__________________
93' W350 Club Cab LE Dually, 3200gsk, grnd fuel pin, timing bumped, pump maxed, pod's, 4" DP, HX35/14cm, 2" SJ lift, Goerend TC, McMaster built 518 82' W350 sb Crew, 6" SJ lift, 20x10 M/T Classic Locks, 37x20 Nitto Mud Gapplers, 4 spd, 4BT conversion in its future but currently a 5.9L gasser, long tube headers H pipe 2.5" exhaust with 1 chamber flows, mopar aluminum intake, MSD ignition, edelbrock carb. 94' 3500 ctd 4x4 Sold 98' 3500 ctd Sold 92' W250 ctd Traded |
#17 |
If you must pay the fine give it to them in unwrapped pennies. Call the local news for coverage. maybe some exposure would help
__________________
2001 F350 4x4 C/C dually,12 valve, NV4500 John Deere 5105, Mazda RX7 w/VW turbo diesel done!, 96 VW Passat TDI 47mpg tank after tank |
#18 |
That's total B.S.
I would definetly try to fight that
__________________
TOY LIST '95 Ram 1500 4x4 12" lift, 14 blt w/ Detroit, Dana track lock front, 4.56's, 38's '02 Durango 4x4 Custom paint, neons '03 Dodge Ram 3500 4x4 QCab, H.O. DRW, 6 spd, 4.10's, 05 turbo, to 5" miter stacks, Quad 100 bx w/ smoke switch, AEM 6"cone filter, S.B. D.D., St.scene Gen 1 bumper cover, projection headlights, Whelen 690 strobes, SRT 10 style RAM air fiberglass hood 06 Grand Cherokee 5.7 Hemi 18 ft. Jetboat, '03 Yamaha R1 |
#19 |
What I was told at a Bio-seminar.
__________________
2004, 3500 LB,Laramie, 305/555, QC, 4X4, 48RE, 3.73's, |
#20 |
I need to check into that for sure... may only apply to bio not wmo?
The pennies are a good idea! |
#21 |
From the Motor Fuels Tax License Application - North Carolina Department of Revenue: Who must apply -
"Blender means any person who produces a mixture composed of gasoline or diesel fuel and another liquid, other than an additive, that can be used as a fuel in a highway vehicle. The commingling of products during transportation in a pipeline is not considered blending. A blender who transports any motor fuel for hire by means of a transport truck must also obtain a license as a Motor Fuel Transporter. Gas-1260, Blender Return, is required to be filed by all blenders and is due by the 22nd day following the end of the month. A bond is required for a blender license only if the applicant’s average expected annual tax liability is at least $2,000. When a bond is required, the bond amount is two times the average monthly motor fuel tax liability, minimum $2,000 maximum $500,000. What I don't see specified is the definition of what is a an additive? Isn't your WMO just an additive to your diesel fuel? OK, that may be pushing it just a bit in your case but even so, what about the guy who just disposes of his own oil change oil by adding it to the fuel. Would he need the same license to dispose of 3 gallons of oil as someone running 80% WMO? Is it an additive up to 50% content or have you found that dividing line? If it's an additive under 50%, I think I'd be changing my mix ratio.
__________________
Jay '92 D250 Ext. Cab non-LE (manual windows & locks, rubber floor mat, steel headliner), CTD, MU0090 Ralley, Getrag rebuilt by Jay, 3.54, 18.5 cm, D-Celerator exh. brake, 3" pipe into 4" resonator dumping in front of rear tire, BHAF/Outerwears in Old Smokey Mount, head and tail lights on relays, 3” shoes & GM wheel cyls, Tach-Boost-Pyro-Oil Press-Volts-Water Temp-Air Press-Trans Temp-Fuel Press Gauges, Pump bump and KDP dead thnx to WannaDiesel, '93 Jayco 3500FS TT in tow, 300K and counting |
#22 | |
Quote:
I would first go to court and explain to the judge it was being used as an additive for the low quality ulsd diesel now being sold . How full was your tank ?? Didn't you just pour that WMO in and were on your way to fill up at the pump with #2 when you were stopped and dipped ?? Try it might save you 500 dollars worth of penny's or more it seems this is your first/only violation of this law.
__________________
99 quadcab 1 ton 5spd 3.55 213k 2Lp+1Ip org clutch 21.3 mpg 96 3/4 4x4 ext cab LB auto 20.7 mpg stock for a few more days 94 3/4 4x4 auto 181dv-300hp injectors + boost-L- mystery switch- missing kitty -HAVE YOU SEEN HER??? 89 3/4 2wd auto the original -with a little pump adjustment 69 GTX 440 4spd super track pack 71 340 duster auto 64 sport fury 383 4spd |
#23 | |
Quote:
That's a good idea. You have 45 days to round up 100,000 pennies. I'd get started right away. I like that plan.
__________________
1996 2500 CTD, 4x4, BHAF, Silencer ring, somewhere in a field south of my garage. Tranny- 47RE. 145,000 |
#24 |
caqll your local wells fargo or loomis armed carrier and set up a delivery to the location where the fine must be paid. dont ask me how I know these things
#25 |
They run a check on the fuel when it's any color other than the normal because they're wise to people trying to dye offroad fuel black with WMO to hide the red.
I know that the state labs can test for the percentage of red fuel in your tank but highly doubt they're equipped with the instruments to test for percentage WMO. The investment in the lab would never pay for itself with fines. In other words unless you told them what percentage was WMO I doubt if they could prove it. Fight it and say there was only one gallon of WMO in the tank. In California and a couple of NE states the fine for burning WMO is more than for running offroad, air pollution laws. In fact trucks with the Cummins Centinel oil burning system are illegal in those states too. In many ways they are right, used motor oil has been proven to cause cancer. Products of combustion change the oil and add a few nasties to it as well. If everybody was running WMO I'm certain we'd see a lot more problems.
__________________
Bill '95 2500 4x4 auto '95 3500 5 speed flatbed hauler stock for one day |
#26 |
There is no exception for an additive when its wmo. 1%-100% its the same fine according to the revenue agent that checked me.
I had about 8 gallons of mixed fuel in the tank. He even came back to my shop to see where I filtered it and mixed it. No offroad fuel just on road (taxed paid fuel) and wmo. |
#27 |
I also forgot to mention that they check all your diesels once they find one running wmo.
They use DMV records so if you try and lie about it they fine you without checking. He told me they got a farmer with 7 licensed vehicles. $7000 FINE! If they are registered to your business its a $5000 fine each. He also informed me that I would be receiving a fine from the IRS because of the state penalty. |
#28 | |
Quote:
#29 |
He collected 2 samples from my truck with a hand pump type siphon.
I only had one diesel registered to me so thats the only one he checked. |
#30 |
this is NOT good at all!! I guess exploring "alternative fuels" is a bad thing when normal people do it?
Keep us posted how this turns out and good luck fighting "the man".
__________________
1998 12v quad cab shortbox, Isso pyro and boost guage, 286K stock miles. only muffler is gone; all bark so far! EDIT;4/07- KDP killed, stock converter weak!! Edit- 1-08 tranny still holding, 305k miles, 1 Oddesy battery- been good for -5*f Edit- 4-09- Suncoast converter, single battery being a wimp, 325K 9-24-09- 100 plate and 100' burnout!! 1979 lil red express which after extensive testing was determined to be slower than my old man's 72 Mach 1 w/351 cleveland... |
| Thread Tools | |
| Display Modes | |
