Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > Towing and Hauling / RV
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 03-27-2008, 09:23 AM   #1
goffracing
goffracing's Avatar
my 2500 moves alot while towing my toyhauler help
I have a 2003 2500 4x4 auto. I have had a dually until now and when i pull my toyhauler the thing moves around alot and about scared the crap out of me. this is most noticable when someone passes me. the rear of the truck moves around a good bit.
the question is do i need helper springs or bags since the truck doesnt have them stock like my dually. or should i just get one of those sway bar's that go on the hitch. and yes its a bumper pull and its a touch over 30 feet. and loaded is about 10,000 lb.
thanks.
__________________
2003 2500 slt 4x4 5.9L HO with Auto.
Mod - Airaid cold air, Bully dog power pup set on Tow
goffracing is offline   Reply With Quote
Old 03-27-2008, 09:27 AM   #2
jkitterman
Do you have the trailer loaded properly? What is the percentage for your tongue weight? Go get accurate scale measurements for the trailer.
__________________
2003 2500 6spd Quadcab longbed
jkitterman is offline   Reply With Quote
Old 03-27-2008, 09:33 AM   #3
2003Ram
2003Ram's Avatar
thanks.
I haul a a TH about the same size as well.
When towing I have the rear truck tires at 70psi + if they are "E" rated stock tires or max on the "D's" which I have now (65 psi).
On the trailer side - the trailer should be loaded 60% of the weight in front of the axles, load distribution bars and an anti-sway device has served me well.
I have recently added Timbren springs which has given a little more support with the trailer hitched. The tongue weight is enough to put the Timbrens on the axle. Any side to side movement or body roll is greatly reduced because of this.
__________________
2003 4x4 2500 CTD Quad-Cab 48RE 10.5/4.10's
My own Ram Air with Pro-Gaurd 7 drop in filter - Click for link
Bilstein shock absorbers - They look better black!
drivers seat mod - Click for link
MOD FOR MILEAGE - 1991 Infiniti G20 / 25 MPG
2003Ram is offline   Reply With Quote
Old 03-27-2008, 09:48 AM   #4
goffracing
goffracing's Avatar
it does it with the trailer empty or loaded and i only haul two dirtbikes in the trailer and load them over the axles.
supersprings over load spring is what i was going to have put on today if that would help. it almost feels like body roll its a side to side movement.
it doesnt move if im alone on the rode and no wind. just when people especially trucks pass me it moves a bunch
Old 03-27-2008, 09:50 AM   #5
goffracing
goffracing's Avatar
also yes E rated stock size pirelli's at 70 psi in the rear.
Old 03-27-2008, 10:20 AM   #6
SundayMoney
Do NOT get a sway bar that goes on the hitch. For a trailer as big as yours they won't do a darn thing. Even two of them (one on each side) won't do much.
You need something like a Reese Dual Cam or Equalizer sway control.
You need to verify the correct tongue weight.
I don't see anything about a weight distibution set up either....ya' got one?
__________________
'07 QC,LB,4x4,SLT
5.9,G56
SundayMoney is offline   Reply With Quote
Old 03-27-2008, 10:26 AM   #7
Jeff in TD
Jeff in TD's Avatar
For that setup the first things I'd put on is a good hitch like the Reese, and air bags, and run the rear tires up to 80...
Try that first, anyway. Towing something that size with SRW truck is still going to be different than towing it with a dually was...
__________________
06 Inferno Ram dually Laramie 4x4, stick, jake, B&W, BrakeSmart.
Tows 394F Patio Hauler w/ Honda 500 Foreman, and 680 Rincon.
Jeff in TD is online now   Reply With Quote
Old 03-27-2008, 10:37 AM   #8
goffracing
goffracing's Avatar
i do have a class 4 reese hitch with solid reciever so im well under my hitch limit. i dont have weight dist hitch. i was just going to add the springs. do i need the weight dist hitch ? that just sounds crazy i mean its a 3/4 tn truck or am i just spoiled from having a dually all this time.
not sure on exact tonge weight but it probably atleast 1200 maybe 1300 the truck sags about 8 inches when i put the trailer on the ball.
Old 03-27-2008, 10:47 AM   #9
ellerman
ellerman's Avatar
Equalizer hitch, stabilizer bars or airbags all will help but I think you need to look at the nature of the beast you are towing. Any tag trailer that big is going to be effected by wind (passing vehicles) greatly. If it was a 5th wheel you would hardly notice passing vehicles but on a tag trailer you have that hinge point behind the axle and they are going to sway, dually or not. I wouldn't waste a bunch of money trying to fix the problem unless you are adding something to the rear of you truck to make it level when the trailer is hooked up. Eric
__________________
2001 4x4 QCLB Sport 6spd HO, Carli arms, Carli Coils, Carli Billet shock towers, 3" Sway-A-Way shocks, Carli 3rd gen track bar, Carli Sway Bar Links, Deaver 12 leaf spring packs, custom made long travel air bags, Defiant dual stabilizer, 3rd gen wheels, 295/70R17 Toyo MT's, Centramatic wheel balancers, Edge Juice with Attitude, FASS, MBRP 4", AFE stage 1, Jammer stage 2 injectors, Jacobs Exhaust Brake, DSS steering stabilizer, Luke's links, Southbend ConOFE, Optima Yellows, Royal Service body
ellerman is offline   Reply With Quote
Old 03-27-2008, 10:56 AM   #10
2003Ram
2003Ram's Avatar
You should have a weight distribution set-up, even with a dually. That is the number one fix for your problem. An anti-sway device does work. I have one and use it when loaded in conjunction with the load bars. I can pass or get passed by semi's with no sway issues.
My load consists of: 30' TAG toyhauler with four seat buggy, Honda 400ex, a Tri-Zinger, 100 gallons water, 25 gallons gas, firewood, and all of the rest of my camping stuff.
Old 03-27-2008, 11:16 AM   #11
jballou
I agree, get a weight dist hitch set up and a sway device first. These are gotta haves. Our trailer is smaller only 21' and I thought that I didn't need them----- boy was I wrong, it corrected all of the sway and pull from others passing.
__________________
2004.5 4x4 Laramie auto,4door kid hauler, commander with fuel gauges, GDP walbro, stock wheels and tires for better mileage.
IAFF Local # 4034
jballou is offline   Reply With Quote
Old 03-27-2008, 11:16 AM   #12
SundayMoney
If your truck drops 8" when you hitch the trailer,you have WAY more than 1200-1300lbs of tongue weight. I can drop almost 2000 on my truck and it only drops about 2-2 1/2" . I do have a 3500SRW,but the only difference in the rear suspension between mine and yours is my overloads. With 2000lbs the O/Ls are still 1" plus from coming into play,so my O/Ls aren't supporting any of the weight.
Either its way more tongue weight than you think,or the springs are shot.
Old 03-27-2008, 11:23 AM   #13
jballou
Or it really isn't 8 inches. Get a tape measure.
Old 03-27-2008, 01:23 PM   #14
goffracing
goffracing's Avatar
well i guess it wasnt 8 inches it more like 5 inches.
the truck and trailer are now at the trailer shop getting the hitch and sway control installed so i will report back
thanks for the advice
Old 03-27-2008, 02:44 PM   #15
Rocky
Rocky's Avatar
Same Set-up
I run the same setup as you- 30ft 10,000 lb bumber pull, have a 2500 with a weight dist hitch/sway device and it tows really nice.
__________________
2003 Ram 2500 HO 4x4 Laramie 48RE- Stock Performance
2005 29' Hornet Hideaway Toyhauler TT- 10,000lbs. loaded
Rocky is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
