how much does a 5.9 cummins weigh?
does anyone know how much a 5.9 cummins weighs? I was wanting to buy some engine stands, but I didnt know what one actually weighed fully dressed with fuel system and everything ready to roll. thanks
12 valve - 960lbs
24 valve Common Rail - 1170lbs
24 valve VP44 - ???
Im pretty sure Ive read this question posted before. Do a search for it.
Hope this helps.
Scott
24 valve VP44 - ???
Hope this helps.
Scott
Figure about 1200 lbs. If you mount it from the back side of the engine, its gonna sag, no matter what. Mount it from the side, and will stand up much better.
I'd be curious from where the extra 200 lbs. came from between a 12v and 24v. I know the 24v and 12v head don't weight much different, and the 50 lbs. p-pump would add some fat to the 12v number.
24v with vp44 weighs 1600lbs fully loaded.
as for the other engines check again, those are weight on the engines not fully loaded.
Weighed the engine at a certified scale at a wrecking yard. The engine had just came out of the truck.
Is there a tranny and t-case attached to that engine as well? No way engine alone weighs 1600 lbs.
